Water fill/Generator compartment keys
Would someone please post a picture of the key(s) used for the water fill/generator locks? I’m especially interested in ones from around the 1991 year, since that’s what I have.
The keys for ours were lost, and I’m not sure what to order to replace it. Replacing the locks would be a major problem on the generator compartment - it looks like the locks were installed before the back side of the door was put on.
Here’s a picture of the water fill lock. The ones on the generator door look the same.
Thanks!
Thanks!
Re: Water fill/Generator compartment keys
The water fill is the HUDSON
CH751
The gen box is DECO only marking on the back is D.
Thats on a 93 hope it helps.
CH751
Danke.
Edit: The CH751 is a very common key - quite a few brands use it, and have for years.
- Choptop
My fill/Gen comp keys are the same , not sure if someone switched locks over the past 27 years. My one key for both says MAG on one side and 838 on the other and is not cut at all like 190-b-651's
Turns out I already have a CH751 key, it's the water fill on our trailer. It doesn't match either of the locks on the B190. Therefore, I'm guessing my missing keys are like yours.Choptop wrote:My fill/Gen comp keys are the same , not sure if someone switched locks over the past 27 years. My one key for both says MAG on one side and 838 on the other and is not cut at all like 190-b-651's
I'm not sure mine are the same though. I wish I could remember.
I received a copy of Choptop's key today, thanks! Unfortunately, it's not the right key, either.
I've come to the conclusion that the water fill and generator use different keys - the generator key is narrower.
- Choptop
skater wrote:I received a copy of Choptop's key today, thanks! Unfortunately, it's not the right key, either.
Well we tried !!
I see the keyhole is horizontal but when it’s locked it should be vertical. Could it just be jammed or stuck? Tried any wd40?
The lock works fine - I can "pick" it easily with a small screwdriver and open the latch (which it apparently was when I took that picture). Oddly enough, the key Choptop sent me, if inserted upside down, will turn that lock - but obviously that's not how it's supposed to work. And it won't fit the generator compartment lock at all (too thick), despite the fact that they look the same.lido14co wrote:I see the keyhole is horizontal but when it’s locked it should be vertical. Could it just be jammed or stuck? Tried any wd40?
The lock works fine - I can "pick" it easily with a small screwdriver and open the latch (which it apparently was when I took that picture). Oddly enough, the key Choptop sent me, if inserted upside down, will turn that lock - but obviously that's not how it's supposed to work. And it won't fit the generator compartment lock at all (too thick), despite the fact that they look the same.[/skater wrote:lido14co wrote:I see the keyhole is horizontal but when it’s locked it should be vertical. Could it just be jammed or stuck? Tried any wd40?
Maybe have to replace the whole unit. Here’s one for $15.59. Sort of an expensive key though!
https://www.ebay.com/i/350815828508?chn ... 9718496317
And the wrong color. It also doesn't solve the generator door issue. I was considering something like this, but I haven't given up on the key idea yet.lido14co wrote:Maybe have to replace the whole unit. Here’s one for $15.59. Sort of an expensive key though!skater wrote:The lock works fine - I can "pick" it easily with a small screwdriver and open the latch (which it apparently was when I took that picture). Oddly enough, the key Choptop sent me, if inserted upside down, will turn that lock - but obviously that's not how it's supposed to work. And it won't fit the generator compartment lock at all (too thick), despite the fact that they look the same.lido14co wrote:I see the keyhole is horizontal but when it’s locked it should be vertical. Could it just be jammed or stuck? Tried any wd40?
- Choptop
Have to laugh, not really, when the shipping is over half of what the item costs!
Funny how my key worked both locks but different years, different locks.
Then they’d all be keyed the same. Good idea.skater wrote:And the wrong color. It also doesn't solve the generator door issue. I was considering something like this, but I haven't given up on the key idea yet.lido14co wrote:Maybe have to replace the whole unit. Here’s one for $15.59. Sort of an expensive key though!skater wrote: The lock works fine - I can "pick" it easily with a small screwdriver and open the latch (which it apparently was when I took that picture). Oddly enough, the key Choptop sent me, if inserted upside down, will turn that lock - but obviously that's not how it's supposed to work. And it won't fit the generator compartment lock at all (too thick), despite the fact that they look the same.
I’m hesitating for two reasons. 1, I’m not sure that they’ll work with the thin material (i.e., I might not be able to tighten them enough), and 2, it looks fairly difficult to replace the locks in the generator door.lido14co wrote:Then they’d all be keyed the same. Good idea.skater wrote:And the wrong color. It also doesn't solve the generator door issue. I was considering something like this, but I haven't given up on the key idea yet.lido14co wrote: Maybe have to replace the whole unit. Here’s one for $15.59. Sort of an expensive key though!
Deco-A turned out to be the right key for the water fill! These are the ones I bought. Just one left to figure out...
