Page 1 of 2
Water Heater Door Replacement
Posted: Thu Jan 25, 2018 2:21 pm
by usachris
Re: Water Heater Door Replacement
Posted: Fri Jan 26, 2018 1:18 pm
by 190-b-651
Definitely looks better.
Posted: Fri Jan 26, 2018 1:27 pm
by Choptop
And still available, a linky please.
Posted: Fri Jan 26, 2018 2:55 pm
by usachris
I got mine off eBay. The cheaper ones are painted plastic so I avoided those.
This was the one I bought:
- Aluminum replacement Door
- 2578BB29-51E6-4A7C-B9A5-8D0D692A5E61.jpeg (111.26 KiB) Viewed 15967 times
I bought this parts kit to go with the door but only used the latch, spring, and hinges. Totally worth it.
- I used the latch and hinges from this part kit.
- 8770864F-4D24-49CD-91BC-34274F7B3548.jpeg (122.83 KiB) Viewed 15967 times
Posted: Fri Jan 26, 2018 4:54 pm
by Choptop
Thank you sir, mine is peeling paint I think.
Posted: Fri Jan 26, 2018 8:29 pm
by okaynagan
our door to the water heater was looking so very sad that I took a soap, water and a wire brush to the peeling surface and then painted it with aluminum colored paint. It is happier looking now and just passable for its age.
- refinished door
- hot water port door.jpg (38.3 KiB) Viewed 15948 times
I should have used sand paper to prepare the surface. Too late now, the okanagan found a new owner.
Posted: Sat Jan 27, 2018 8:32 am
by Choptop
okaynagan wrote:our door to the water heater was looking so very sad that I took a soap, water and a wire brush to the peeling surface and then painted it with aluminum colored paint. It is happier looking now and just passable for its age.
The Okanagan will be missed.
Posted: Sat Jan 27, 2018 6:13 pm
by baggydew
I ordered a replacement aluminum door but it came in as gloss white. Trying to match the paint for a 94 model. Does anyone know the correct paint code?.....or where i can get a color match? The color code on the door for exterior color is very confusing. There is a group of letters and numbers that don't seem related.
Posted: Sat Jan 27, 2018 7:41 pm
by okaynagan
The color code on our 95 B190 is YN. The color name is silver metalic.
I looked up the color for the 1994 B190 and the color name and code appear to be the same. Here is a link if you want to look up the color code and name for your airstream.
http://www.paintscratch.com/touch_up_pa ... oline.html
I went to a local auto paint store with the color code from the door sticker and they mixed the paint and loaded it into a spray can. I opted to use the base coat paint with a can of the acrylic clear coat to for the second coat giving it a nice glossy finish.
Posted: Sat Jan 27, 2018 8:06 pm
by baggydew
Thank you so much. I'll give this a try!
Posted: Sat Jan 27, 2018 8:51 pm
by Choptop
okaynagan wrote:The color code on our 95 B190 is YN. The color name is silver metalic.
Thanks, that will help alot !!
Posted: Sun Jan 28, 2018 2:15 pm
by usachris
See if you can get it in a high heat formulation. That would keep that door looking good for a longer time.
Posted: Sun Jan 28, 2018 7:08 pm
by baggydew
That's definitely something to consider. Thanks.
Posted: Tue Feb 13, 2018 12:45 pm
by baggydew
Found a good, inexpensive spray paint match for our campers. If your paint code is YN, Dupli-color makes the paint in an 8oz spray can. The Dupli-color # is BFM0236 Silver Charcoal Metalic. (1Q, 14, D1,9Z, YN )
The can says it's a Ford color. I bought it off the shelf at Autozone for $8 and change. Refinished my heater access door and put on several layers of clearcoat. Great match!
Posted: Tue Feb 13, 2018 1:49 pm
by Choptop
Thanks ! been trying to find a good match for my stove vent and other spots.
Any one know the color code or close for the blue ?
