1989 Airstream B190 Ford Econoline E350 Chassis
Now on an Ebay Auction Number 321806712125
Go to this link to see additional photos: https://imageshack.com/a/XIn4/1 click on "dk_1kgal" to access the album or individual albums, as shown below.
Airstream
Airstream B190
By dk_1kgal | Created May 13, 2015 2:58pm
This vehicle was created by Airstream to tow their larger trailers and provide the owners with a travel vehicle while the trailer was in camp. It has a towing package and set up with electric brake control. It is rated to tow 5,000 lbs that does not mean that you can put a motorcycle on the front end and tow 5,000 lbs, it was not meant to have anything on the front end of the vehicle blocking the radiator.
This ad has been run before about a month or so ago, a gentleman came to look at it and decide not to buy it, his comments as I recall were:
The engine seems to run hot.
I want to tow two Harley Motorcycles on a trailer and put one on the front.
The rust on the rear was not indicated in the ad and seems a little more than I expected.
The generator does not start.
I think that was about it. Response to those questions are
The Engine seems to run Hot:
460cc/7.5L temperature? http://www.ford-trucks.com/forums/10052 ... ure-s.html
The engine was worked on 11/21/2012
The old refrigerant was replaced and a retrofit kit was installed, it was recharged with oil and R134a and tested for operation and leak test.
Manifold set was installed
Fan belts were replaced (alternator, air pump, a/c and p/c)
Drive be lt tensioner assembly was replaced
Radiator Cap Replaced
Thermostat and housing gasket was replaced
Coolant was replaced and cooling system was flushed
Oil filter
Hoses replaced: by pass, radiator upper and lower, heater hose to heater core, and all clamps
Spark Plugs and wires replaced
Air Filter
Distributor cap and rotor
Radiator (yep it has a new one!)
Fuel injector O-ring kit
Distributor mounting O-ring
Total cost $3,396.00
Well that was and easy question to answer, No you can’t do that, this was asked during a uphill test drive that he requested at the end of the interview.
The ad was very explicit and originally I had photos of the outside but Ebay has a 24 picture limit and I had to delete those photos to answer a request for photos for the inside! But he did have the photos of the rust prior to looking at the vehicle.
The generator was worked on 10/30/12. I start the engine (both batteries are on battery tenders), generator and top air conditioner (to put a load on the generator) once a month. After he mentioned it I got it started after three tries and waiting for a few minutes between to make sure I didn’t flood it. I think it needs to be cleaned and tuned up again.
The carburetor, air filter and exhaust pipe was replaced and tuned up in 10/30/2012 cost at that time was $429.99.
Other work Done:
Front Doors worked on in 11/16/2012, Both front door window motors were replaced. $704.00
Before a trip in May of 2009 I had the transmission serviced and checked, all was ok. $133.00
And a CARFAx was run by me in 04/1/2005 with nothing reported!
Mechanically maintained. Shows her age (surface rust on hood, rear corners, upper rear windows on the frame). The surface rust is very light since the vehicle has been in southern California it’s entire life, needs a paint job, and is still in terrific condition with LOW mileage. Have the Original Manuals on all components, Owner Guides, Promotional Material, and Extensive Vehicle Records from current and previous owners. More info and pictures available. Come take a look at it. Email Me: Digital_Eye@hotmail.com
VIN: 1FDHS34G2KHA25231
35,264 Miles
* 7.5 liter V8 (460 cu. In.) w/ Towing Package (hitch, receiver and wiring)
* 2.8 KW Generator & 11,000 BTU Roof Air Conditioner w/ Heat Strip
* Cruise Control & Power windows, locks
* Sink, stove, refrigerator, toilet, shower, furnace, Fan-Tastic Ceiling Fan Vent with Thermostat,
Convertible couch/bed, sliding overhead double bed, and much more.
* Like New Tires
* 2012 AC-retro kit installed and upper engine work done 3.5k
* 2012 left and right window motors replaced and some switch’s replaced
* 2012 carb replaced on generator and cleaned
Upgrades:
New Radio Head Unit Receiver w/ USB input & Pandora® control SONY CDX-GT565UP
2 Relatively New Heavy Duty Batteries
Rack / Storage carrier on receiver
CB radio and XM radio antennas in place
New closed cell foam bed topper
1989 F-SERIES/ECONOLINE/BRONCO FORD DO-IT-YOURSELF SERVICE MANUAL
1989 Ford Electrical & Vacuum Trouble-Shooting Manual
1989 Truck Wiring Diagrams Econoline (E9UB) FP
4 Sale: 1989 B190 Ford 460hp 7.5l engine San Diego Ca
- Jay
- New User
- B190 Year: 1989
- Surface rust on hood drivers side
- IMG_183719.jpg (90.92 KiB) Viewed 5462 times
- Surface rust on hood passenger side
- IMG_183618.jpg (97.2 KiB) Viewed 5462 times
- Surface rust on corners and back doors
- IMG_184527.jpg (107.03 KiB) Viewed 5462 times
- Tucsonan
Re: 4 Sale: 1989 B190 Ford 460hp 7.5l engine San Diego Ca
Rust is not a crime ...I like the patina!
- Jay
- New User
- B190 Year: 1989
The RV has been in southern California for all of it's life and has been 4-5 miles from the coast it's just the paint that Airstream used over the original ford metal flake was the problem. When I do pass one of the B190's on the street the all seem to be repainted.
