Cab Center Console and Captain's Chairs
Make it comfortable inside
Cherstream
Post by Cherstream »
I have a 1992 B190 and my center console in the cab is terribly broken. The Ford dealer says they no longer make anything like this. Does anyone have an idea where I could find a part to replace the center console that covers the engine. It would be nice if it had all the features (cup holder, storage space, change holder) of the original, but I can live with it if it doesn't, as there is just no way for the current one to look nice.
The Captain's chairs also need replacing, so I would also appreciate any hints on this. Is there a specific make or model that works for replacing these that I should be on the lookout for?
Thanks in advance for any advice you may have.
Cheri Sicard<br>Author, The Complete Idiot's Guide to Easy Freezer Meals (2011 Alpha Books)<br>Owner 1992 Airstream B190<br>
Re: Cab Center Console and Captain's Chairs
For the center console, junkyard perhaps?
I think the captain's chairs are pretty standard RV captain's chairs; I know Flexsteel made some of them.
Planck
Post by Planck »
Here are some on ebay: http://motors.shop.ebay.com/i.html?_fro ... le&_sacat=
Not your year, but I would start by finding out what years will fit. Local wrecking yard might have an interchange manual. Then, keep checking ebay and other web sites till you find one. Or, some wrecking yards are tied in nationally and may be able to locate one.
Good luck
Cherstream
Thanks guys. I will start the search for the console. Even though it's not the right year, eBay was encouraging. According to the guy at my RV repair shop, the chairs are going to be a problem and have to be found used. But it does seem like any standard chair would fit. Has anyone replaced their captain's chairs?
Cherstream wrote:Thanks guys. I will start the search for the console. Even though it's not the right year, eBay was encouraging. According to the guy at my RV repair shop, the chairs are going to be a problem and have to be found used. But it does seem like any standard chair would fit. Has anyone replaced their captain's chairs?
Are your chairs in mechanically good condition? If so, I'd just get them reupholstered instead of replacing them. Almost certainly cheaper, and guaranteed to fit.
Cherstream
No not in good mechanical condition at all, also not in good physical condition.
URStruly
Post by URStruly »
Dennis Carpenter can get most anything for a Ford. Give him the vin#.
http://www.dennis-carpenter.com/trucks.php
The seats in my 1991 are Flex Steel Captains chairs. Flex steel 91452 001 277 BUSR PA.
Follow the Butterfly.URS.
Cherstream
Thank you so much, I will check with Dennis!
RCR
Post by RCR »
If I'm not mistaken, 92-96 models are the same so that may increase your chances of finding a doghouse cover. I found one at the local junkyard that was in perfect condition just a couple of months ago. I ended up giving my "pretty good" older one away.
For the console attachment, like others have posted - eBay is the ticket.
1995 WHITE B190 7.5L - 108k
Cherstream
Thanks, that helps and is quite encouraging!
Lakeboy
New User
Post by Lakeboy »
[image]
Press the release tab located inside the console and pull up to remove your console box
[/image]
