Help, about to leave for Colorado and California and have a
Posted: Thu Jul 17, 2014 4:51 pm
by vzfit
Please help,
I'm about to leave in my '95 and the water filter under the sink is cracked and leaking. Where can I get another one? What is the part #? Does Home Depot have it?
Thanks,
Sam
Re: Help, about to leave for Colorado and California and hav
Posted: Thu Jul 17, 2014 7:59 pm
by Keystone
Hi Vzfit
I put this one (see below) in my '94 and it's still working fine. Also, I found that you can also wrap that cracked pump strainer in gorilla tape after gluing and limp along with that until the replacement arrives.
Safe travels! I'll be on the lookout for you as you drive through CO.
Keystone wrote:I bought this one for my '94--it's a Jabsco in-line pump strainer model 36400-0000:
http://www.westmarine.com/jabsco--pumpg ... 32_003_024
It's not the same model as was original to the van, but it's worked fine these past 4 years since I installed it. Good luck!
Posted: Fri Jul 18, 2014 3:28 pm
by vzfit
Thanks Keystone!
I had to just rip it out and bypass the filter.
Unfortunately, my new 190 will not be making this trip. I was up until 10pm last night fixing random things.
Fix list so far:
1) Transmission leak-front seal (local shop repair)
2) Shower head and hose replacement
3) Inline water filter under sink
4) Wet vac carpet
5) Seal hole in propane hose under middle side door
To Do list before the B190 is road worthy:
1) Find/fix the fuel stoppage in the generator line
2) Service Generator
3) Secure propane tank (it rattles around)
4) Figure out the fridge operation
5) For some reason my monitor just quit working all of the sudden.
Please share any info on the above 5 topics on the to do list.
After all of this, I am still confident this rig will be awesome.
Thanks,
Sam
