1997 B190 coach battery location
Posted: Mon Feb 22, 2016 4:34 pm
by mistercmo
just bought my first B190, a 1997 model.
Where is the coach battery located?
Thanks,
Charlie
Re: 1997 B190 coach battery location
Posted: Tue Feb 23, 2016 4:01 pm
by SeaQuinn
Howdy
I have a 1999 with the same bath set up as the 1997. If you open the two way back doors where the spare is, the coach battery should be to the right at the bottom of the closet under a wood panel. Should be a red battery on/off switch there too. However, I have seen set up under the couch too
. Let me know how you make out.
Posted: Sun Feb 28, 2016 12:49 pm
by mistercmo
Thanks! Yep, exactly there
no cutoff sw tho. Ford dealer had put in a new batt for me but (once I located it) I found it was not deep cycle (as requested) so, back to the dealer...
cheers
