PCM/ECM/ECU???? Same thing?
Posted: Mon Jul 07, 2014 12:13 pm
by jb1rd73
I am ready to do the PCM/ECM upgrade as I don't know what else to do with the hesitation/hiccup/stutter issue, it got noticeably better with the tune up but is still prevalent. From what I have read on here and a couple of Ford specific forums the PCM rebuild/upgrade has seemed to rectify the problem for a lot of folks. My question is this, is the PCM the one that is in the front DS top of the engine compartment? Also I want to make sure that that is the one I need to take out and send, is there another computer or are PCM-ECM-ECU the same thing? Thanks in advance, Jason
Re: PCM/ECM/ECU???? Same thing?
Posted: Sun Feb 21, 2016 7:24 pm
by Abie Sea
I am interested in your diagnosis of hiccups and stutters. I have an 89 and have encountered similar problems. One response I got was to investigate the fuel pump which is in the tank and occasionally over heats and that creates problems. This fits with my experience that when I switch to the back tank the problem stops and after a while I can switch back to the front tank and it works well. I have not yet fixed it yet to confirm the diagnosis. It is expensive to have done and I do not have the specific id for the pump.
Posted: Mon Feb 22, 2016 7:08 pm
by Keystone
Have a look on this forum at the old thread I started called, The 94 460 Fuel Pump Problem. One common theme is that we all had the problem when it was hot; the problem resolved when things cooled off. The new fuel pump solved the problem for me and many others. But you will maybe need two fuel pumps?
Also, I don't recall having heard of an 89 with the ECM issue. My 94 already had this fixed by previous owner.
Or yours could be a third thing. Good luck and keep us posted on your progress.
Posted: Tue Feb 23, 2016 8:28 am
Keystone wrote:Have a look on this forum at the old thread I started called, The 94 460 Fuel Pump Problem. One common theme is that we all had the problem when it was hot; the problem resolved when things cooled off. The new fuel pump solved the problem for me and many others. But you will maybe need two fuel pumps?
Or yours could be a third thingImage. Good luck and keep us posted on your progress.
Yeah, I'm not sure the '89 even has an ECM; if it does, I think it's very rudimentary.
On the original question: I've always heard the PCM, ECM, and ECU are essentially the same thing, but different terms used by different manufacturers.
