Just purchased 1993 B190 and have a few questions...
Posted: Sat Nov 10, 2018 6:41 pm
Hi everyone!
My husband Luke and I just bought a lovely 93 b190 in pretty good shape.
Electrical issue...The generator runs but doesn't power the van...I discovered the battery under the couch is shot when I went to check the wires running to positive terminal post and the post lifted freely off the battery....The van has 2 batteries under the hood and a fancy battery selector switch mounted to the dash board that I'm not sure how to use it has 4 modes 'Off', '1', '2', and 'On'. I'm hoping to find the generator feeding the AC loads when I swap out the bad battery under the couch.
DOOR LATCH...My most pressing issue right now is the cargo side door latch stopped working the day after I bought the van. Now I have been searching through the posts and have ordered new cables for around $10 and installed them
...the trouble is that along the way of repairing the latch a white anchor clip broke off of the key lock tumbler and I never saw what it looked like before the metal rod was detached. I think I read someone's post before I began the repair about epoxying the post in lieu of replacing the white plastic anchor but now I can't find it....Does anyone have pictures of this or know which post it was? I'm currently keeping the door closed by lashing it with webbing and not driving it if i put the latch back on I won't be able to open the door...hoping to fix asap...
Also I am thinking of having the van looked at by an RV shop to check out the systems. Can't hurt but not sure how expensive that is...LP heat works, haven't tried the stove yet, and I don't think the fridge or water heater are firing up. Had to learn quick how to weatherize the plumbing because when I brought her home from Virginia i had about 48 hours before we had a 28 degree night here in CT.
Looking forward to many trips in the van!
Cheers, Erin
Cheers, Erin
