Page 1 of 2
Sewer Hose Door
Posted: Sun Aug 13, 2017 10:27 pm
by BuddyR
Does anyone have a source to buy a new sewer hose access door and frame replacement?
Seems like it may have been modified to fit the curve of the van. Mine is brittle and has chipped edges.
Thanks.
Re: Sewer Hose Door
Posted: Sun Aug 13, 2017 11:04 pm
by 190-b-651
Ebay search
Rv sewer hose door and a bunch come up.
Re: Sewer Hose Door
Posted: Sun Aug 13, 2017 11:05 pm
by 190-b-651
Here
Re: Sewer Hose Door
Posted: Mon Aug 14, 2017 8:08 am
by BuddyR
I will check. Mine looks different than the one pictures here unfortunately
Re: Sewer Hose Door
Posted: Mon Aug 14, 2017 9:26 am
by 190-b-651
Mine is a little different to. I haven't replaced the sewer door yet but did the electric cord door and found a exact match on amazon. The only hose that fits in that compartment is the cheap hose that came with mine. I've been thinking about trying to put in a new tube and door that would let me fit the newer type of hose. The ends are larger and the door isn't large enough but im not sure if there is enough room between the black water tank and the floor for a larger pvc tube to fit.
Re: Sewer Hose Door
Posted: Mon Aug 14, 2017 5:33 pm
by BuddyR
I changed the electric door to an Aluminum plate and a chassis connector so the cord is separate. The old power cord was a mess and it gets tweaked stuffing it under the tub. It works well.
Re: Sewer Hose Door
Posted: Mon Aug 14, 2017 8:02 pm
by 190-b-651
Im thinking about doing the same BuddyR its is a pain especially on the campsites if I nose in for a better View.
Re: Sewer Hose Door
Posted: Mon Aug 14, 2017 8:15 pm
BuddyR wrote:I changed the electric door to an Aluminum plate and a chassis connector so the cord is separate. The old power cord was a mess and it gets tweaked stuffing it under the tub. It works well.
This was a mod I always wanted to do to mine, and I never got around to it. If nothing else, it'd be nice not having that open airway to the outside to reduce draftiness in the bathroom. Also, if you camp in cold weather, you could easily upgrade to a cord that remains flexible in cold temperatures.
I want to do it to our trailer, too.
Re: Sewer Hose Door
Posted: Tue Aug 15, 2017 7:58 am
by BuddyR
I will try to get a picture posted soon. I have some more upgrades since I posted last also.
Re: Sewer Hose Door
Posted: Wed Aug 16, 2017 10:12 pm
by BuddyR
Here are a few pics of the replacement for the power cord setup on my B190.
Re: Sewer Hose Door
Posted: Wed Aug 16, 2017 10:54 pm
by 190-b-651
I like it good job. But it looks like its on fire!!
Re: Sewer Hose Door
Posted: Wed Jan 03, 2018 11:12 pm
by Oldbagpipe
I went that way with the power cord, as well. However, I went with a chrome marine installation. The old door wouldn't stay shut and seemed like easy access for rodents and bugs. This works great!
Re: Sewer Hose Door
Posted: Wed Jan 03, 2018 11:30 pm
by Choptop
And yet another mod I would like to do !!
Re: Sewer Hose Door
Posted: Thu Jan 04, 2018 8:44 am
Oldbagpipe wrote:I went that way with the power cord, as well. However, I went with a chrome marine installation. The old door wouldn't stay shut and seemed like easy access for rodents and bugs. This works great!
Does the chrome cover screw closed, or is it spring loaded, too? (I know the power connection is right there, so the goal of stopping bugs/rodents is met, I'm just curious how the cover works.)
Re: Sewer Hose Door
Posted: Thu Jan 04, 2018 5:54 pm
by mountaindent
I understand that the electric cord placement going in and out of the camper is "technique sensitive". Did you do this work yourself or did you get a camping store or electrician to do the conversion. I would have an easier time wrapping the cord up outside the camper and placing it more carefully in the space. The way it is now I start entering the cord in the space and then open the door to make sure it is not pushing or pulling too much on the plumbing. Oftentimes, I have to withdraw the electric cord to make sure it does not cause a problem with the piping which would cause leaks.
My sewer door is also chipped and faded. However, it does look different than the picture. I will keep looking...it is the rounded or curved on the edges.
