Front mounted Tow Hitch
Towing with the B190
weekender
Post by weekender » Sat Jun 05, 2010 9:29 am
Has anyone done it? Any drawbacks? I would like one for a cargo carrier. I like my bike rack on the rear because it does not require any modifications for clearance. The cargo carrier on the back can frequently drag if I'm not paying attention on driveways. I expect I would have less clearance issues with the cargo carrier on the front.
Thanks for any thoughts
Post by Alaskan » Sun Jun 06, 2010 12:53 pm
Its not a bad idea actually.
If I were going to do that, rather than having a single on-center mount like a rear trailer hitch has I'd make a mount bolted to the bottom of both frame ends, therefore having a pair of square tubes supporting it, next size smaller that a hitch, which is 2 inch.....so I'd use 1 1/2" square tube
The alternative of course might be to use a rear hitch and do whatever kind of modifications it might take to install it on the front.
I'll take a look, stay tuned
weekender
Post by weekender » Sun Jun 06, 2010 9:33 pm
I've been in touch with our local U Haul dealer-- they have a good reputation here. They have done a front hitch on the Ford E350 before-- there is a standard hitch that is listed in their "fit software". I'm having it done this Friday, $250 installed, 2" receiver. I'll let all know when it is done, and post some pix.
Also having my electrical connection converted to a twist connect by the dealer--about $175 for the parts and install
Steve
Post by Alaskan » Sun Jun 06, 2010 10:05 pm
Steve....I put one of those big ole rear carriers on a friends rig, one of the things I didn't like was it moved up/down at the outer edges quite a lot due the the receiver not being a very tight fit
I corrected that by drilling a 9/16" hole centered on the bottom and tig welded a 1/2"-13 nut over that hole...that way I could run a short 1/2-13 bolt in to pinch the receiver tube therefore taking all the slack out.....which made the entire carrier much more stable.
Being out it the front you are going to see all that movement...
Contact:
Post by skater » Mon Jun 07, 2010 7:41 am
weekender wrote:Also having my electrical connection converted to a twist connect by the dealer--about $175 for the parts and install
Is this for the 120 volt connection? I've wanted to do that but never got around to it. It'd definitely be a good upgrade, though.
weekender
Post by weekender » Mon Jun 07, 2010 8:50 am
Thanks for the tip on the bolt-- I may have that done as well.... I'm just the type that would be driven crazy by the movement.
weekender
Post by weekender » Mon Jun 07, 2010 8:56 am
Hey Skater,
Yes, that is the 120 connection-- The original port cover broke--dealt with it for a couple of years. Finally last year looked into the replacement port-- only in white-- painted it silver to match-- cover broke with just a couple of uses. The twist connect port is much better, heavier construction, though still white only. I mostly use the electric hookup at home, most camping I do is boondocking. I have never enjoyed feeding or pulling the cable thru the port, so I suspect I will like this option much better. Pix will follow once I get it done.
Steve
Post by Alaskan » Mon Jun 07, 2010 2:09 pm
Just an example for location....drill a 9/16" hole to begin with, that size allows a little clearance for the 1/2" bolt.
I used a stainless 1/2-13 nut so there wouldn't any rust issues later, tig welded around it and used a 1/2-13 x 1" bolt..snug it up tight against the receiver tube...
weekender
Post by weekender » Fri Aug 27, 2010 1:32 pm
So I did end up having a front hitch installed, and used it for a recent 2 week trip. I have a "Hitch Haul" with a plastic box on the front. I found it was a great place to store items I did not want or have room for inside the van-- leveling ramps, a camp stove, camp grill, life jackets and paddles for kayaks-- Outdoor storage is all that is missing from our units.
Turns out, you cannot even see the rack or box from the drivers seat-- not an issue as long as you remember it is there in traffic!
PS, I used the rear hitch for a bike rack and 2 bikes-- the bikes work well on the back, as there are no clearance issues.
Post by Alaskan » Fri Aug 27, 2010 2:12 pm
And...it doesn't interfere with any of the lights nor prevent air flow to the radiator...???
weekender
Post by weekender » Fri Aug 27, 2010 3:08 pm
Nope, not in the slightest. In fact, I felt like the engine was running cooler than normal, but I am sure that is just my imagination!
Post by Alaskan » Sat Aug 28, 2010 5:34 pm
Toss in a couple pictures...
weekender
Post by weekender » Sun Aug 29, 2010 11:36 am
I'll post specific pix when I get a moment, but for now, you can see it in my photo gallery-- Weekender-- second page, for my main photo gallery, then last pic is a new album where I have started posting pix of our 2 weeks in Canada-- there are several of the van with the hitchhaul and box in place
Post by Alaskan » Sun Aug 29, 2010 11:50 am
Looks good....lotta stuff hanging out there in front
Are those reflectors around the carrier red....?
Thanks for all the pictures and participating here...
That rigs has Alaska written all over it..... :lol:
Dave...
General Mopars
Re: Front mounted Tow Hitch
Post by General Mopars » Fri Nov 01, 2013 12:13 am
I'm glad I found this thread. I just bought a B190 with a class III tow hitch receiver in the front. I had absolutely no idea what it was for. I imagined somebody flat-towing this tiny motorhome behind some gigantic much-bigger motorhome.
