Fresh water plumming diagram needed.
mustangman
Post by mustangman »
I need a water routing diagram for a 1999 b190. The van owner's son took it apart to replace the pump, some of the parts have been lost, and I think the hot water heater will have to be replaced. any help that you can give Me will be "Greatly" appreciated . :?
Ouch.
I don't think there's much to it. Unfortunately my '91 is probably going to look different, but I think the pump just feeds into the main cold water supply from the city connection.
One thing I would do if I were in your position is put a water heater bypass in.
Alaskan
Post by Alaskan »
MM....I'll take ya some pictures of the water system....stay tuned
An option on the hot water heater rather than buying an entire new one, they make a kit.....comes with a new aluminum tank, two-piece styrofoam insulator and new safety pop-off valve.
Here:
http://b190.com/modules.php?name=Forums ... opic&t=133
Alaskan
Post by Alaskan »
Anything more specific I'll help ya if I can...
mustangman
Thanks for Your help. the water supply is on hold untill the Engine fuel feed problem can be solved. It wont pump fuel from either tank.
