My fresh water tank leaks inside cabinet until it is about half full. I assume I have a crack or hole.
How do you get the tank out of the cabinet?
sos
leakin fresh water tank
- New User
- B190 Year: 1996
Re: leakin fresh water tank
I always assumed you had to disassemble the cabinet.
That is what I have gathered from poking around the forum here. Can you tell at all where it is coming from? I would think there are many things you could seal it up with in lieu of removing it. Epoxy comes to mind, 3M 5200, also.
Just get on the Bus!!
Mike & Barbara
Mike & Barbara
- New User
- B190 Year: 1996
I can't seem to find it so it may be in the back where I can't get to it without taking it out.
Wondered if this is a common problem.
No, it isn't. Usually this would only happen if the water in it froze.sosfromtexas wrote:I can't seem to find it so it may be in the back where I can't get to it without taking it out.
- New User
That is what I have collect from poking around the meeting here. Can you inform at every one where it is coming from? I would think there are a lot of belongings you could seal it up by means of in lieu of removing it.
