Propane tank removal
It's a gas
silvertrooper
Re: Propane tank removal
Post by silvertrooper »
Last photos...still need to fill it and verify everything works, but that's for later!
Looks great! I should do that to mine, which isn't nearly as bad as yours was.
Oldbagpipe
B190 Year: 1989
Post by Oldbagpipe »
Nicely done! This is on my 'list', but still a ways down. I'll be back to this thread when ready. Thank you
kstills
Post by kstills »
Very nice!
A bit anal repainting a tank no one will see because of a few scratches, though, no? :wink:
Rugster
Post by Rugster »
silvertrooper wrote: Thu Mar 24, 2022 6:41 pm Hey Rugster,
Who did you have do the work? I've got a similar problem with a leaking shut-off valve, and LP places say they won't work on the chassis-mounted tank, and RV places say they don't do LP, or it's too old (1996) for their shop.
I'm now just thinking about doing the work myself--looks fairly easy since the tank is empty. Problem is, I don't know what valve to use. I suppose I cold just remove it then see if I can match it...
Thanks for any tips!
Branden and the Tourtle
Branden - sorry for the very late reply, but I only just saw your question. It's probably a moot point by now, but the work was done at Allied Propane in Richmond, CA.
babsy
B190 Year: 1998
Post by babsy »
What is the name and size of the fitting to the right of the fill valve in the bottom picture ? I just found out that fitting must be stuck open as I have a small leak even when tank not over filled. I suspect the last person who filled it didn’t know how and he overfilled it. I need to replace it but don’t know exact name and model of the part. Any help greatly appreciated????
Barbara
babsy
B190 Year: 1998
Post by babsy »
Does anybody’s know if this will fit my original propane tank on my 1998 B 190?
Emerson Fisher 3/4 in. MNPT External Relief Valves for ASME Containers - 250 PSIG
I’d so I can get it in time for my trip. If not sadly won’t be able to use refrig or stove.
Thank you
Barbara
babsy
B190 Year: 1998
Post by babsy »
This is the pressure relief valve off my 1998 tank. Does anybody know where I can order a replacement???
Thank you
Barbara
DROC
Post by DROC »
LOVES filler nozzle does not fit my original filler on my propane tank (1995 B190) Is there an adaptor sold to fit?
DROC wrote: Tue Jun 16, 2026 9:13 am LOVES filler nozzle does not fit my original filler on my propane tank (1995 B190) Is there an adaptor sold to fit?
That's very strange, it's the standard motorhome tank, and they should have the adapter. Could it be a situation where the attendant has only filled bottles before and wasn't aware of the adapter?
