Page 1 of 2
Propane Valve Replacement
Posted: Mon Aug 09, 2010 2:54 pm
by rubyslippers6232
Does anyone know how much it might cost to replace the propane valve at a repair shop? Ours has a leak...when we turn it on there is a hiss. Just wondering what we might be looking at. I don't think it could really cost all that much, but who knows?
Posted: Mon Aug 09, 2010 4:36 pm
by Alaskan
Make sure its not just the hose where it leaves the valve....I've had 2 that leaked there rather than at the valve itself
The crimp on the hose was bad...
If its leaking around the stem that the handle is attached to, look close, there is a nut there you can tighten slightly that increases the pressure on the packing ring.....it looks to be left-hand thread as I see the notches on the corner of that nut
Posted: Mon Aug 09, 2010 4:38 pm
by rubyslippers6232
Thanks, I will double-check that.
Posted: Mon Aug 09, 2010 4:43 pm
by Alaskan
I added something there for ya....
Posted: Mon Aug 09, 2010 4:44 pm
Mine used to do the same thing - leaking out the handle. It stopped a while back and hasn't done it since. A bit scary, but I'll go with it. :)
Posted: Mon Aug 09, 2010 4:46 pm
by rubyslippers6232
Well, it was in the fall when we last tried it, so operating on that theory, I will open it up and maybe it will not do it now. I love these suggestions! Keep 'em coming!
Posted: Mon Aug 09, 2010 4:54 pm
by Alaskan
Did ya see this that I added....?
Posted: Tue Aug 10, 2010 9:10 am
by rubyslippers6232
Thanks again...I will definitely check that out before taking it somewhere.
Re:
Posted: Fri May 10, 2013 4:22 pm
by Tucsonan
Alaskan wrote:Make sure its not just the hose where it leaves the valve....I've had 2 that leaked there rather than at the valve itself
Add my '94 to this last "issue" list too. I will check the hose and also see if that nut can be tightened. ...Can't express how useful this forum is for a 20 year old Bvan! I have saved a ton of money and time. I wonder if I'll ever run out of little things to fix? LOL ...Rick
Re: Propane Valve Replacement
Posted: Fri May 10, 2013 5:23 pm
by Alaskan
nope you won't....and its well worth it
The alternative is very costly....( a new B-type van conversion )
Posted: Fri Mar 28, 2014 3:59 pm
by Mark
Dang, just filled the tank, turned it on and propane stated venting out from somewhere around the valve. I hope I can fix this without having to drain the propane. How the heck would I do that anyway?
Posted: Sat Mar 29, 2014 7:11 am
Mark wrote:Dang, just filled the tank, turned it on and propane stated venting out from somewhere around the valve. I hope I can fix this without having to drain the propane. How the heck would I do that anyway?
I think shops usually burn it off by hooking up a heater before working on it.
I don't think you want to try fixing it, especially without removing the propane. Think about it - a highly flammable gas, metal tools and parts... This might be a job for the pros.
That said, try turning it off and back on, and be sure you open it the full way. Your leak may stop until you can get it repaired.
Posted: Sun Mar 30, 2014 11:24 am
by Mark
Thanks, I'm going to see if tighten the nut behind the actual handle does anything. Hopefully it does. If not, I'll take it somewhere to have it fixed.
Posted: Mon Mar 31, 2014 1:01 am
by Mark
Nope, it was already tight, I'm going to have to take it somewhere.
Posted: Mon Mar 31, 2014 7:01 am
Mark wrote:Nope, it was already tight, I'm going to have to take it somewhere.
Yeah. If yours is doing the same thing mine was, I think the issue is that the packing material that seals the stem wears out, so it starts leaking through there. We had a shop fix it, which included replacing the knob. It never leaked after that!
