1993 Ford B190 Airstream Van - $29,500 San Diego
Posted: Fri Dec 31, 2021 5:03 pm
Here is a quick run down of this particular van:
58,XXX miles (we still drive it so it might go up slightly)
Ford 460 V8 Engine with 3 speed tranny + overdrive
ABS
Run’s perfect and no leaks of any kind
Van was purchased August 2020 with 53,XXX miles
Full tune up was performed to bring all systems up to schedule including
Full brake service including new rotors
Full tune up
Transmission service
All new belts and hoses
New batteries (both coach and engine)
New fuel pump
New smog pump
New headlights (xenon)
New A/C system converted to R134 (this was expensive to do)
Back up Camera
I know that I am missing stuff but basically the van is completely reliable and the engine purrs!
Now for the wheels and suspension!
The “Baja Grocery Getter” 8” inch lift was done by the folks at Weldtec
I also had them put in a custom rear leaf spring that can hold up to 1000lbs tongue weight
New BFG’s KO2’s
Black Rhino wheels
Fox Steering Dampener
Fox shocks with reservoirs throughout - all upgraded
Limited split differential
New control arms
Large diameter front sway bar
Class IV hitch can tow 10000 lbs
Over $8K spent on all of the bells and whistles - you can easily get to your camp site!
Here is the link to the video of the build from Weldtec:
https://www.youtube.com/watch?v=C0ggxG8MBWQ&t=113s
Clean interior
The interior is in great condition.
No modifications.
Onan Generator
Overhead A/C
Sink
Toilet
Shower
Hot Water heater
Large fresh water tank (30 gallon)
30 gallon black water tank
20 gallon gray tank
New black and gray water dump valve
Whole house heater
Propane tank under the van
Upgraded 3M insulation at walls and side doors
Sound deadening material added to walls and side doors
Refrigerator - 3-way power (110V, Propane, 12V) - Never used
4 burner stove / Oven
Microwave
Countertop extension (not shown in pictures but comes with van)
Powered vent fan above oven
Overhead powered fan above sleeping area and bathroom
USB outlets
Power drivers seat (Flexsteel)
Passenger seat rotates toward cabin (very useful)
Real solid oak cabinets
All interior lights have been converted to LED
Brand new curtains with black out backing
Also have the original curtains
Side Awning
Lots of storage and closets
Large pull out upper bed
Couch jack knifes into a bed and also has cup holders
3 seat belts at couch
Full 30amp shore power system
I know I am missing stuff....
Here is the CL ad where you can view pictures:
https://sandiego.craigslist.org/csd/rvs ... 37220.html
Also I have all of the receipts for the work performed since I have owned it.
These vans have a very strong following and once you experience them you will understand why. The interiors are timeless, very well laid out, and the mechanics are tried and trued. If parts are needed they are easy to find at any local auto parts store and inexpensive to service. We took the van on several week long trips up to the Pacific Northwest, inland deserts and shorter local trips. You could easily live in this rig full time. If you are looking for a good reliable van to travel in, this one is worth considering. Price is firm at: $29,500
VIN: 1FDJS3467PHB48189
ABS
Full tune up
New fuel pump
New smog pump
Back up Camera
New BFG’s KO2’s
Black Rhino wheels
New control arms
Clean interior
No modifications.
Onan Generator
Overhead A/C
Sink
Toilet
Shower
Hot Water heater
20 gallon gray tank
Whole house heater
Microwave
USB outlets
Side Awning
