31 PICS ARE IN MY GALLERY
https://www.b190.com/app.php/gallery/album/48
1999 Airstream B190 Camper Van in Northwest Indiana.
One of the last to have ever been manufactured, this Airstream camper van conversion is a 19-foot, self-contained & fully operational class B motorhome. We are the third owners. The first owner put 151,000 miles on the vehicle & then installed a new JASPER remanufactured engine. The new engine has fewer than 35,000 miles on it. The vehicle runs great! No accidents, no water damage, no airbag deployment. The CARFAX is clean.
1999 Airstream B190
Ford E350 Chassis – 185,835 miles; 34,835 on new engine.
VIN# 1FDSS34S4X8A00641
AIRSTREAM VIN# 1B9KGVA24XJ301352
Automotive Equipment
• 6.8L Ford V-10 Triton Engine
• HID headlights & integrated signal housings by Vantage Optics
• BF Goodrich heavy duty all terrain LT265/75R16 tires
• Drive side & passenger air bags
• Automatic transmission/overdrive
• Tilt steering wheel
• 6-way driver power seat
• Dash air conditioner
• Kenwood radio w/Bluetooth, CD player, auxiliary inputs & 6 speakers
• Power mirrors w/Longview side mirror extensions for towing
• Power locks
• 4-wheel anti-lock braking system
• New DFFE sensor (pressure feedback)
• Dual pillar electric transmission temperature gauge & mechanical vacuum gauge
• Tru-Cool - Max low pressure drop auxiliary transmission oil cooler
• Safe-T-Plus steering stabilizing control system
• Air suspension system bags
• 35 gal. fuel tank - regular gas
• Blue Sea Systems dual USB 4.8A socket mount charger with intelligent device recognition maximizes charge rate for phones, tablets, or other mobile devices
• Original Ford Owners Manuals & 3-ring binder w/manuals & instruction sheets, etc. for components & appliances
RV Systems
• 22 .4 gal fresh water tank
• 27.5 gal gray water tank
• 9 gal black water tank
• 11,000 BTU roof air conditioner
• 12,000 BTU furnace w/digital wall thermostat
• 6 gal Atwood water heater
• Control panel monitoring system inside RV
• Heated holding tanks
• Locking fresh water fill tank
• On-demand water pump
• 9.8 gal LPG tank
• 2012 2.3k Onan-Cummins generator w/emissions kit
• Progressive Dynamics Inteli-Power 4600 series converter/charger with Charge Wizard (35 amp)
• Two 6v Lifeline deep cycle, marine grade, AGM house batteries
• City water hook-up
• 35' shore power cord
• Garmin RV 770 GPS w/voice command
• Garmin digital traffic receiver
• Adapters for 50 & 20 amp hookups
• Progressive Industries portable EMS RV surge protector - 30 Amp
• 20’ sewer hose w/connections
• 25’ fresh-water hose w/pressure regulator
Interior Features
• Fiberglass wet shower w/sink, chair height porcelain toilet & exhaust fan
• Insulated side walls
• Marine-grade Vitrifrigo 4.7cf AC/DC refrigerator/freezer
• 700W microwave
• Atwood 3-burner range w/oven
• Stainless steel double-bowl sink w/single handle faucet, pull-out sprayer & built-in soap dispenser.
• 6’ galley w/drawers & Corian countertop w/flip up extension
• LED interior lighting
• 110v interior & exterior outlets
• Power range hood w/light & fan
• Dining table
• Insect screen for back lavatory window
• Swivel passenger seat
• Rear curbside closet
• Commercial rubber tile flooring throughout the van
• Custom-made drapery w/blackout liners
• 3 smoke detectors & carbon dioxide/propane detector
• Pull-out queen-size sleeping area over cab w/bunk ladder
• Pull-out 72”x46” gaucho bed
• Reading lights over sofa & in cab-over sleeping area
• Fan-tastic roof vent with wall thermostat
Exterior Features
• Aerodynamic raised fiberglass top – interior height 6’4” - w/1-piece front window
• 2 Diode Dynamics 6”-wide amber fog lights
• Spare tire inside rear doors
• Sewer hose compartment
• TV antenna mounted in roof w/booster
• Pre-wired for solar
• Roadside exterior storage in running board below floor
• Rear center brake light
• Chrome front & rear bumpers
• Pop-out windows on rear & side doors
• Towing package w/brake controller
• Porch light
• Garmin backup camera & front bumper clearance camera
• Gen-turi generator exhaust system
• Full-length awning (needs replacement)
Mechanical Upgrades
2016 Upgrades:
• Ball Joints - Shocks - Sway Bar Bushings - Steering Shaft - Tie Rods
2018 Upgrades:
• In-dash cab AC completely overhauled
• New window gasket installed on front cabover window
• Replaced 10 ignition coils
2022 Upgrades
• All new radiator hoses installed and radiator flush
$35,000 or best offer
