Table Related information for all years....
Make it comfortable inside
Re: Table Related information for all years....
Wow, what is that? Mine just had a hole...the bright "ring" on the outside looks the same (without the metal pieces), and then the center is a hole. It looked like this. (I'm not sure if that's the correct size, it was just what I found by searching on "rv table leg support recessed".)
ya skater...its a bit different for sure, I think the 1996 I got from ole member Joe in Florida for my friend in Alaska had that same post-mount.
Thinking there is some kinda wire spring-clip that he is missing.
Wakeslayer
Post by Wakeslayer »
Mine had the one that VanDBTR showed with the 4 tabs on it, however the center cap was gone. I just have a tapered table leg that went right into it. I bought something similar or the same as Skater showed in his link. We got tired of stepping on the tabs cause they hurt... The bottom bracket on the table also has the tabs. That I did not replace.
Are you sure that cap doesn't just pop out? Is your table pole tapered?
Just get on the Bus!!
Mike & Barbara
kitemanks
Post by kitemanks »
My 1994 B190 didn't come with a table too. I uncovered the hole through the floor and now I'm looking at pictures to see what I'm making. The pictures in earlier posts are very helpful, however could someone post pictures detailed pictures of their base. I'm looking to tell weather there is a cone or a flush mount and a cone as well used together to make the base.
Thanks
kitemanks
Post by kitemanks »
The height of these tables would be good too.
