Furniture replacement vs. re-upholstery
- Tucsonan
Well, I'm finally getting around to the captain's chairs and sofabed in my '94. Since upholstery shops are so pricey, I am considering buying all new pieces (Pricey also!)
I stumbled on a website, "Shop4Seats.com". Their prices seem the most reasonable.
If anyone has recently re-upholstered or replaced any furniture, and has recommendations or advice, it would be priceless!
I am also considering replacing the sofabed with a dinette/bed, if I can get one to fit. Opinions?
Thanks! Rick
Thanks! Rick
1994 B190, Sahuarita Arizona
"... but it's a dry heat!"
Re: Furniture replacement vs. re-upholstery
I haven't had anything reupholstered in years, so no help there. Like you I found that the captains chairs are pretty pricey.
Someone here did have a dinette instead of the couch. I don't think it was also a bed, though. Pictures were posted, I think - definitely search around for it.
- WBCCI: 8008
I have recently replaced my captain's chairs with a set that came from a new Toyota Sienna. I like them because they recline with a foot rest. They weren't cheap at $650 and some custom bracket work but I think they turned out great. I won't have pictures of them installed until next week because I'm out of town till next Wed. I'll post some when I return. I am also looking for either a replacement for the couch or recovering it. I was thinking of trying to modify a futon cover slightly to make it fit.
I hope this helped a little.
-Tony
-Tony
- Attachments
- !B8mGtLgCWk~$(KGrHqIOKjYEynSViPR4BM3eyy6iIQ~~_3.jpg (56.44 KiB) Viewed 17760 times
1993 B-190
WBCCI: 8008
Fort Collins, CO
WBCCI: 8008
Fort Collins, CO
- Tucsonan
Thanks Skater,
I found the photos in the gallery and emailed Russ about them. It looks great!
Tony,
I found the same ad. It looks like the seller has quite a few more pairs. I hesitated because of the "custom" mounts that would be required. Funny that I live in the RV capitol (AZ) and I can't find a showroom for RV furniture?
Rick
Tony,
Rick
- Tucsonan
Oops,
Regarding the dinette conversion, ...I accounted for the width of the inverter, but forgot the generator housing behind it. (really!?) So that answers my question for me. No dinette for my '94!
- WBCCI: 8008
Just an update on the chairs I have installed. There's not enough room to recline the driver's seat but the passenger's seat is quite comfy. Next step I decided is to recover the couch to match the chairs.
1993 B-190
WBCCI: 8008
Fort Collins, CO
WBCCI: 8008
Fort Collins, CO
- Tucsonan
Nice!, ...you did a great job. How do you like the built-in seatbelts? I went ahead and ordered some online. I will post some photos when they come in. I am seeing about getting the couch upholstered to match as well. Now I need to figure out how to post photos on this board!
- WBCCI: 8008
The built in seat belts are pretty comfy. I like that they are lower on the shoulder and don't rub on the neck. The seats are a bit bigger so it's more difficult for me to crawl from the driver's seat to the rear.
1993 B-190
WBCCI: 8008
Fort Collins, CO
WBCCI: 8008
Fort Collins, CO
- Tucsonan
I removed the engine cover extension/drink holder from my '94 and am replacing the remaining "slot" with a map pocket. This makes "spinning" around to get to the back much easier. Not sure, but if you have room from removing the seatbelts, you may be able to position at least your passenger seat closer to the door (my seat base has a second "set" of mounting holes at the base on the floorboard)...unless it blocks the seat from rotating.
- WBCCI: 8008
Thank you! Removing the cup holder was key. It took me a while to figure out how to remove it because I didn't find any screw heads. After finding the release lever it slid right out!
1993 B-190
WBCCI: 8008
Fort Collins, CO
WBCCI: 8008
Fort Collins, CO
I'm missing the front door on my 94 center console would love to have one if you guys aren't going to use yours anymore. In addition What type of mods were done to make them swivel and such? Did you use your stock set up and then bolt them to it?? My seats are going to need attention soon, the cabled levers are beginning to break down.
- WBCCI: 8008
I don't think I'll be using the center console on mine and would be willing to part with it. I would need to make sure it's not damaged first.
When I switched out my seats I kept the same swivel mounts and sliders. I also reused the cable levers to swivel the seats on the new ones because they were still in good shape. When reusing the sliders I also extended the adjusting lever so I could reach it with the larger seats.
I can post more pictures in a couple weeks when I return to CO from ND.
1993 B-190
WBCCI: 8008
Fort Collins, CO
WBCCI: 8008
Fort Collins, CO
- Tucsonan
I will check mine, ...I took it off a while ago, and I believe it was missing it's door too. If it's intact, you can have it.kitemanks wrote:I'm missing the front door on my 94 center console would love to have one if you guys aren't going to use yours anymore. In addition What type of mods were done to make them swivel and such? Did you use your stock set up and then bolt them to it?? My seats are going to need attention soon, the cabled levers are beginning to break down.
I went ahead and purchased some new seats online from "Shop4seats". I used the original "swivel" pedestals and motor unit from the van. I removed the electrical controls and cables from the old seat, and they are loose under the "skirt" right now. I may scratch build a new mount, but haven't decided yet.
- WBCCI: 8008
I'm kinda bummed I just had my couch redone because I just found this on my local craigslist. If anyone in Colorado is looking for a replacement couch, here's a brand new option for only $50. Let me know if I can help a fellow B190 owner in anyway.
http://fortcollins.craigslist.org/rvs/4443475833.html
-Tony
-Tony
1993 B-190
WBCCI: 8008
Fort Collins, CO
WBCCI: 8008
Fort Collins, CO
- Eagle
Does anyone have any idea on how to remove the existing couch? Mine has seen better days and I would like to replace it.
