Making fluorescent lights LEDs
Posted: Fri Sep 15, 2017 6:40 pm
by okaynagan
- led toplight.jpg (26.82 KiB) Viewed 14147 times
It a is much like a grade school science project; off of Amazon or eBay one may obtain a 5 meters of LED lights on sticky tape, strip the guts out of ones existing fluorescent lights and replace them. We found the results very satisfying.
There are dozens of YouTube videos on this conversion. Being warned from one of them that the sticky tape may fail to stick and is not always reliable we placed globs of rubber silicone at strategic places for insurance.
- gut and place LEDs
- gutted.rewired.jpg (20.93 KiB) Viewed 14147 times
Re: Making fluorescent lights LEDs
Posted: Fri Sep 15, 2017 11:00 pm
by Kentuckian
Interesting mod! Keep us posted on how it works for you! Any idea how many lumens of light output?
Posted: Mon Sep 18, 2017 5:26 pm
by okaynagan
- clean out the hardware leave only the switch.
- gutted.jpg (123.7 KiB) Viewed 14106 times
Lumens! Funny you should ask, I wish I'd known to asked to begin with. Apparently the size chips have to do with the amount lumens. 3528's that I started with only had 5 lumens per chip. The second strip we worked with (5050s) had 15 lumens per chip, what a difference! But in either case enough chips were placed to be brighter than the fluorescent light they were replacing.
Another difference are daylight chips as opposed to the warm light chips. Perhaps it's just my opinion that the daylight seem to put out more light. They are working champion!
Posted: Mon Sep 18, 2017 6:23 pm
by Choptop
NICE!!!!!!!!!!!!!!!!!!!!!!!
Posted: Tue Nov 21, 2017 1:02 pm
by brefmint
This is a brilliant mod. I've been shopping for an LED replacement for our fluorescent but will go this route instead. Thanks for sharing!
Posted: Tue Nov 21, 2017 2:13 pm
by mountaindent
okaynagan wrote:led toplight.jpg
Yes, the fluorescent light brings back primary school flashbacks and just does not provide satisfying light. When I get a lull in all my projects I bet I start focusing on that light now! Nice job.
Posted: Tue Jan 23, 2018 2:25 pm
by usachris
okaynagan wrote:It a is much like a grade school science project; off of Amazon or eBay one may obtain a 5 meters of LED lights on sticky tape, strip the guts out of ones existing fluorescent lights and replace them. We found the results very satisfying.
What was your total cost/time invested to build?
Posted: Thu Jan 25, 2018 2:29 am
by okaynagan
usachris wrote:okaynagan wrote:It a is much like a grade school science project; off of Amazon or eBay one may obtain a 5 meters of LED lights on sticky tape, strip the guts out of ones existing fluorescent lights and replace them. We found the results very satisfying.
Gee, that is hard to say for 5 meters of the 12v 5050 led runs about $6 to $7 on amazon prime
https://www.amazon.com/s/ref=sr_pg_2?fs ... 1516858197; we already had the jumper wires, solder and silicone adhesive on hand. If don't count your labor time it 's a pretty cheap hack. 16 feet reel of leds did one ceiling fixture and 2 task light fixtures.
- sink task light in " big blue the okanagan"
- bb1.jpg (89.69 KiB) Viewed 13563 times
- sis b190
- v3.jpg (55.19 KiB) Viewed 13563 times
- ceiling fixture of Okanagan
- bb1a.jpg (128.63 KiB) Viewed 13563 times
converting fluorescent lights LEDs
Posted: Fri Feb 09, 2018 3:59 pm
by okaynagan
Well I am at it once more. This time in the b190.
Clearing out all the components of the fluorescent fixtures and gluing down the LED strips. I've been soldering leads together, apparently there clip-on connectors that make this job much easier; they're not near as time-consuming as soldering is. However only two these connectors came with the LED strip.
- LEDs glued down and soldered to each other in the older fluorescent fixture.
- toplight.jpg (129.31 KiB) Viewed 13346 times
While I was at it a coat of white spray was added to the shroud of the light fixture; that take care of that yellowing plastic. Looks like a new fixture, it sorta is. It is much brighter now too.
- lite ceiling fixture with LED strips replacing the fluorescent tubes
- ceiling fixture.jpg (20.55 KiB) Viewed 13051 times
- what a different a coat a paint makes with these fixtures.
- painted.jpg (35.55 KiB) Viewed 13051 times
Posted: Mon Apr 29, 2019 9:14 pm
by Ricci
Hi! this is so helpful. Would you please update the link to the lights. I think the ones you used are no longer available so the link takes me to a suggestion page and now Im confused again!
Posted: Tue Apr 30, 2019 7:06 pm
by okaynagan
It seems the price of them has gone up since I first posted this. They can still found for under $10 for a 16foot reel. search Amazon or eBay for "12v LED strips 5050 daylight".
