While its out, change the oil. Hard to do in situ unless you have a special drain set up.
Glad you found the problem.
Fuse on back of control board?
Re: Fuse on back of control board?
Good advice. And consider modifying the generator compartment in the camper to allow the oil to be changed without removing the generator from the camper.Planck wrote:While its out, change the oil. Hard to do in situ unless you have a special drain set up.
