I figured I'd show you guys the images in case anyone was wondering how big certain panels actually are on the roof, and to see what you guys thought of the four options I've come up with, or if you have any better suggestions.
My main goal is to cram as much wattage as possible on the roof, without having to resort to penetrating the fiberglass surface or increasing the height of the vehicle appreciably. I think the best way to do this is to bolt some cross-bars to the stock roof railing.
The plans are in order of what I think is best, A being my first plan... E being my last.
- Layout A requires mounting a panel onto the top of the Airconditioner housing. I think this would be OK, and we could even drill holes in the housing for brackets without damaging the roof of the van. The 180 watt panel could easily be attached to support beams mounted across the pre-installed railing on the aft half of the van.
- Layout B requires mounting a panel onto the top of the air conditioner housing, and then puts two identical panels on rails mounted across the pre-installed railing. This might be the easiest install, as it uses three identical panels. **upon further thought, this is now my first/primary choice at this time I'm just not excited that Zamp's panels are so overpriced...
Layout C would mount three panels on beams across the pre-installed railing. The 100 watt panels might hang over the edge of the van slightly, but would still be within the footprint of the van mostly.
Layout D is the same as C, but modified to just two panels incase we cannot install something over the shower-vent without blocking it, although blocking it may not be a problem anyway.
Layout E is my least likely. It would require mounting either with sticky feet or drilling holes, as the railing does not extend that far forward. I'd like to keep the install easy with just two 180 watt panels, however I want to keep the in the back half of the van which has a railing to mount to, and is several inches shorter than the front half.
First, the measurements and layout of the roof in it's stock layout, all measurements are rounded to the nearest 1/4 inch, and are only as accurate as you expect some stranger on the internet to be. I encourage you to double-check your own measurements before you use my numbers for any of your own projects. The 24" measurement from the back of the AC to an extension off the rear of the van is a measurement that would create an overhang off the back end, but would still be within the footprint of the van without extending past the rear bumper:If anyone wants the powerpoint file that these are saved in, so you can drag and manipulate panel locations for your own layouts or diagrams, feel free to PM me your e-mail and I will send it to you.
And finally, some comparisons of the various sizes of panels I am considering:
