1999 Battery Cabin Battery Location?
On my 93, it was under the hood. Where is and how does one get to the cabin battery on a 99 B190. I have a new engine battery, but the systems monitor indicates a low state of charge. I'm assuming there is another battery because the interior lights won't turn on without the ignition on when I seem to remember they used to. Any help would be greatly appreciated. Thank you.
"I do not feel obliged to believe that the same God who has endowed us with senses, reason, and intellect has intended us to forego their use..." -- Galileo Galilei
Thank you VERY much! Amazingly the owner's manual shows it located under the couch. I found it exactly where you described and it is indeed bad. Explains the occasional sulfur odor I smelled in the closet as well. All systems are go now. Thanks again Hubie!Hubie wrote:Hi,
The house (cabin) battery is located in a metal box enclosure on the passenger side of the van at the rear. Open the right rear door and remove the wood panel immediately in front of you which covers the battery box. There she sits...
Hubert
