Floresent light
Camping World has them, and I've also seen them in several RV parts departments. Fair warning - they're like $50, which seems high considering you can buy a florescent 4-foot 120 volt fixture for less than $20.
- craigmar
fixture replacement
This might seem like a dim-wit reply but have you checked to make sure the light tubes are good. When we purchased our van, the overhead light did not work and we too, checked for power, found that we had power and then bought new tubes and haven't had a problem since.
Re: fixture replacement
I was assuming they'd already tried that, but it's good to mention it!craigmar wrote:This might seem like a dim-wit reply but have you checked to make sure the light tubes are good. When we purchased our van, the overhead light did not work and we too, checked for power, found that we had power and then bought new tubes and haven't had a problem since.
First off....be sure to check the rocker-switch at the end of the light to make sure the 12-volts are passing through it.....if not, they are easy to replace with a swtich from Radio Shack
That original Thin-Lite fluorescent ceiling light is very costly complete as its a much better quality than you'll find at Camping World...but, the OEM ballast can be easily replaced and can be purchased very easily from a nice fellow in California, John Drake...he is listed on the Thin-Lite website as a source for the ballast
http://www.thin-lite.com/thin_lite_repl ... _chart.htm
Its a OIB-116 @ $19.00
Scan down in here:
http://www.solarseller.com/thinlite_bal ... _lite_.htm
John Drake Services
john@solarseller.com
Scan down in here:
John Drake Services
