Tires and sizes
Posted: Mon Jul 27, 2020 10:17 pm
by Jersey747
Hi guys ...what are the largest tire size and rim combination you can install without rubbing on frame or requiring modification to bodywork etc ?. It’s a 94 B190 but has the running boards removed .....Will 33 in diameter tires work???
Thanks Paul
Re: Tires and sizes
Posted: Wed Jul 29, 2020 4:18 pm
by Jersey747
To answer my own question ......I found out today at Tire shop .... BF Goodrich AT tire 265/75/16 fit.....approx 32.5 in diameter with a bit of trimming to front fender...Tried the 285 but that would require a good chunk of rear wheel well to be chopped ..
So any bigger would require body or chassis lift kit etc.....hope that helps someone in the future
Re: Tires and sizes
Posted: Tue Oct 27, 2020 5:10 pm
by Harper
yes, thanks for posting that. Im tryjng to decide on which winter winters right now. I see a bunch of 17" bf Goodrich for sale used, but unless I bust out the angle grinder, that just isn't gunna cut it right now.
I do hope to lift it with lockers but, yeah. $$$
Thanks for posting this.
