I bought a Master Flow MF-1050 after reading
this and other articles about it (or another model just like it).
A couple notes:
1. It didn't seem to want to start against a heavy load - I blew two fuses before I figured out that it ran fine without a load but when I tried to start it against 60 PSI in the tire, it didn't do anything. I'm not sure if this was a break-in anomaly or if it'll happen all the time, but it's better to start it then hook it up. (It did start okay against 50 PSI later, so it may have just been a break-in quirk.)
2. The tire fill connector was pretty annoying, especially with my hubcaps, since it's hard to get my fingers in near the valve.
3. The pump ran quietly and although it took a few minutes, it was able to run the rear tire up to 80 PSI without a problem.
4. Between the cord and the hose, there's just enough length to get to the left rear tire from the camper battery. Not sure about the right rear tire, but it didn't look promising (though from the engine battery it'd be fine).
5. It includes a nice carrying bag and an extra fuse. It's actually a pretty decent compressor, it seems. Of course since I blew the two fuses that came with it, I'm now down to zero extra 30 amp fuses...but they're just standard automotive blade fuses that are available anywhere.
I'm going to think about doing what the guy in that link did - permanently mount it somewhere with a small air tank to give it a buffer. I also would like to replace the inflator nozzle, which means all new hose from the pump (due to the way it's set up - the hose and nozzle are one piece and they use a non-standard connection at the pump). It'd be nice to have a connection or two somewhere outside the camper, too.
