Page 2 of 2
Re: Propane tank removal
Posted: Sun Jun 05, 2022 9:43 pm
by silvertrooper
Last photos...still need to fill it and verify everything works, but that's for later!
Posted: Mon Jun 06, 2022 7:07 am
Looks great! I should do that to mine, which isn't nearly as bad as yours was.
Posted: Sun Aug 07, 2022 11:29 am
by Oldbagpipe
Nicely done! This is on my 'list', but still a ways down. I'll be back to this thread when ready. Thank you
Posted: Tue Aug 09, 2022 1:42 pm
by kstills
Very nice!
A bit anal repainting a tank no one will see because of a few scratches, though, no?
Posted: Sat Apr 08, 2023 10:33 pm
by Rugster
silvertrooper wrote: Thu Mar 24, 2022 6:41 pm
Hey Rugster,
Who did you have do the work? I've got a similar problem with a leaking shut-off valve, and LP places say they won't work on the chassis-mounted tank, and RV places say they don't do LP, or it's too old (1996) for their shop.
I'm now just thinking about doing the work myself--looks fairly easy since the tank is empty. Problem is, I don't know what valve to use. I suppose I cold just remove it then see if I can match it...
Thanks for any tips!
Branden and the Tourtle
Branden - sorry for the very late reply, but I only just saw your question. It's probably a moot point by now, but the work was done at Allied Propane in Richmond, CA.
Posted: Thu Jun 29, 2023 4:48 pm
by babsy
What is the name and size of the fitting to the right of the fill valve in the bottom picture ? I just found out that fitting must be stuck open as I have a small leak even when tank not over filled. I suspect the last person who filled it didn’t know how and he overfilled it. I need to replace it but don’t know exact name and model of the part. Any help greatly appreciated????
Barbara
Posted: Thu Jun 29, 2023 6:16 pm
by babsy
Does anybody’s know if this will fit my original propane tank on my 1998 B 190?
Emerson Fisher 3/4 in. MNPT External Relief Valves for ASME Containers - 250 PSIG
I’d so I can get it in time for my trip. If not sadly won’t be able to use refrig or stove.
Thank you
Barbara
Posted: Fri Jun 30, 2023 1:01 am
by babsy
This is the pressure relief valve off my 1998 tank. Does anybody know where I can order a replacement???
Thank you
Barbara
Posted: Tue Jun 16, 2026 9:13 am
by DROC
LOVES filler nozzle does not fit my original filler on my propane tank (1995 B190) Is there an adaptor sold to fit?
Posted: Wed Jun 17, 2026 3:02 pm
DROC wrote: Tue Jun 16, 2026 9:13 am
That's very strange, it's the standard motorhome tank, and they should have the adapter. Could it be a situation where the attendant has only filled bottles before and wasn't aware of the adapter?
