Page 11 of 11
Re: B190 database
Posted: Sun Aug 03, 2025 8:01 pm
brooklynbus wrote: Sun Aug 03, 2025 4:52 pm
Hi Skater,
I'm now on my second b190. My current, which I've had about 3 years is a June 1999 build with Airstream production number 301389. The plaque I took the image from only shows these last 6 digits. I'll try to find another plate.
Seems like their numbers were all over the place by the end of its run.
Not sure if you need the Ford Vin.
I actually track them by the Ford VIN because, if any ads include a VIN, that's almost certainly the one that it'll have.
Yours would be the new highest VIN we have - definitely interested in both VINs for yours.
#301389 should be a 2000 B190 (the chassis might be 1999, though). If so, the Airstream VIN would be: 1B9KGVA24YJ301384
Re: B190 database
Posted: Wed Aug 13, 2025 11:35 am
by brooklynbus
Hi Skater,
Close on the VIN. I've actually got: 1B9KGVA23YJ301389.
The Ford VIN is: 1FDSS34SXXHB62743
Showing June 1999 build.
That last year of production must have been a bit all over the place.
I think you said the final years they were just called a B van maybe.
Anyhow, hope this helps. Keep up the cracking work.
F
Re: B190 database
Posted: Tue Oct 14, 2025 12:50 pm
by thatChrisLady
Howdy Skater
Date purchased 1/1/2025
FORD: 1FDJS34H4NHB47331
Airstream: 1B9KGVA22NJ300472
Re: B190 database
Posted: Tue Oct 14, 2025 1:09 pm
by thatChrisLady
Skater I was looking at your? Spreadsheet and mine doesn't fit the criteria either
1992 with #472
I just registered #GillyB190Van
on the database here too
Re: B190 database
Posted: Wed Oct 15, 2025 8:22 am
thatChrisLady wrote: Tue Oct 14, 2025 1:09 pm
1992 with #472
I'm not sure what you mean - #472 fits right in the known sequence numbers for 1992 models (for 1992 models, #345 is the lowest I have, and #481 is the highest I have).
Thanks for supplying the VIN info! I've added them to the database. It wasn't in the database before.
Re: B190 database
Posted: Wed Oct 15, 2025 8:27 am
brooklynbus wrote: Wed Aug 13, 2025 11:35 am
Hi Skater,
F
I just realized I never added yours! Done now. Roughly speaking, where are you located? (City and state is fine, or whatever you're comfortable with.)
Re: B190 database
Posted: Fri Oct 17, 2025 8:04 pm
by RivMan
Adding my new purchase here!
Ford VIN: 1FDJS34G7PHA17764
Airstream VIN: 1B?KGVA26PJ300512
The third character isn’t stamped fully, but may be a 9.
Advanced 4x4 conversion in 2017.
Currently in Colorado, moving to Michigan.
-Rob
Re: B190 database
Posted: Sun Oct 19, 2025 8:03 pm
RivMan wrote: Fri Oct 17, 2025 8:04 pm
-Rob
Added it! The 9 is correct - all of the Airstream VINs for these start with "1B9".
We're up to 22% of the B190s in the database!
