Intermittent Missing / Jerky at cruising operation
Posted: Fri Jul 13, 2007 3:07 pm
by Roger
Hi to all ;
I've recently purchased a '94 B190 in FL and drove it home in MN and it ran like a charm. recently it has started a intermittent engine miss / jerky operation. I've taken the B190 to the local Ford dealership to get the problem resolved and today I received a call that all codes check good BUT they do see the problem when doing the test ride. They are unable to repair the problem after replacing Throttle plates; testing and cleaning all injectors; replacing the PCV valve. Also I should add that occationally I can smell gas fumes.
Does anyone have some ideas as to what I can replace or ?
The Bvan is a '94 5.7 460 Ford
Thanks,
Roger Arnesen
#5888
Posted: Fri Jul 13, 2007 3:32 pm
I'm sort of thinking the same thing the dealer is - induction cleaning.
First thing I'd do is get a can of BG44K. It's expensive ($22?) or something, but it does work very well. You dump it in your gas tank as a fuel system cleaner. It's only available at service shops that carry BG products; you won't find it at Autozone. If you can't find it, or don't feel like looking, Seafoam is also highly recommended and should be available at your local parts store. Dump either one in the gas tank and run it through the engine per the directions - it just may do it, and it's not going to hurt.
This is assuming the fuel and air filters are in good shape (if you haven't changed them since you bought it, do so - they're easy and cheap).
If that doesn't work, my next step would be to check the plugs, wires, distributor cap, and rotor (again, if you haven't changed/checked them already). Those are all fairly easy except that ONE spark plug is a BEAR to get to (the one on the driver's side, all the way forward).
Posted: Fri Jul 13, 2007 4:04 pm
by Alaskan
fuel system problem...
with injection a large part of the fuel is returned to the fuel tank...this sound like a lack of fuel or fuel pressure.....this problem may not be detacted in the Ford dealer shop hooked up to the computer, only under load at road speed.
I'd take it to another Ford dealer and show them what the first dealer had done w/o finding the problem
Thanks For the input
Posted: Sat Jul 14, 2007 2:39 pm
by Roger
Alaskan & skater,
Thanks for your input. I think the dealer is on a mission by calling other dealers to find input from a mechanic that has resolved this issue in the past. I'll keep you guys up on the status.
What a great site !!!
Thanks,
Roger 5888
Posted: Sat Jul 14, 2007 5:43 pm
by Alaskan
Thanks for checking back Roger..
Let us know what resolves that problem...
The Final Solution
Posted: Mon Nov 26, 2007 11:38 am
by Roger
It took a long time and a few $$$$ but the solution to the Jerky problem turns out to be a computer problem. The computer was taken out by a tune up shop, sent in for repair and software upgrade and now my B Van runs like a top. My next adventure with this unit is Coach wiring,,,,Thanks everyone for your input.
Roger
Posted: Tue May 13, 2008 9:27 pm
by ChasingRain
I had the same problem with mine. After new plugs, wire, coils, distributor cap, rotor, fuel filter, and fuel system cleaner, it was still there. Round too cost a lot to diagnose (and repair), new Oxygen sensor, MAP sensor, Distributor Stator, ignition module, and rewiring some of the grounds to the PCM. Now it's good at cruising speed, but still missing a little at idle, which they said was probably a bad or dirty injector, but it's good enough for now.
Finally the root of the problem
Posted: Thu May 15, 2008 7:09 pm
by Roger
After many dollars spent on the problem a new "UPGRADED" computer module corrected the problem. Runs like a top
Posted: Mon May 26, 2008 10:12 pm
by baggydew
I have experienced the same problem with my 1994 B-190, Started acting up a year ago at 90K after 30K faultless miles of my driving. I have changed everything and checked everything EXCEPT computer. I can't find a rebuilt computer anywhere. Where are they available and how much do they cost? Help!!!
Posted: Tue May 27, 2008 9:58 am
It looks like spayallpets had the same problem with the computer.
They were able to get one from Airstream, if I understood
what they were saying.
ECM
Posted: Mon Jul 04, 2011 3:09 pm
by RobertL
This is a common problem with the 7.5.
After many years of sitting around or running around the ECM tends to go completely bonkers.
Mine acted up this Friday. After the engine warmed up a bit the stalling begins. Letting it cool down for an hour or so allowed me to run it.
This of course was after a $400 plus tow charge to move it across the blazingly hot desert of Nevada back to Vegas.
ECM are readily available from a number of companies, programmed to your specific VIN#.
Mine was done by Solo Electronics Company.
Posted: Mon Jul 04, 2011 8:02 pm
I'm going to lock this, since better/updated info is available in the other thread that's linked above.
