I'm in the process of rebuilding my fridge compartment after a leak destroyed it.
It's a 1990 model
First question - does the wood shelf under the fridge sit on any rails, or is it resting directly on the wheel well?
The wood was pretty destroyed, so I have nothing to go on, but I don't see any holes in the side walls for supports the shelf would sit on. However, it seems like having the shelf rest directly on the wheel well would cause it to grind on the metal and the finish and the wood, etc...
Once I have the shelf installed, I'll build a new metal pan for the fridge to sit on. Then I need to seal that pan to the rest of the enclosure (for water protection as well as propane fumes). On this front, I have some aluminum duct tape that uses butyl rubber as its adhesive (and makes a water proof seal) - seems like this would be a very clean simple way of sealing the inside of the compartment. Any downsides to using the butyl rubber sealant here?!?
Refrigerator Compartment
slapthecat
Re: Refrigerator Compartment
On my '93 the wood shelf does not sit on the wheel wheel. It is secured to the side panels of the fridge cabinet above the wheel well. When I get to my B190. I'll see if I can get a photo for you.
Here is a photo from underneath the fridge. The shelf is secured to 3/4" wood strips on both sides of the Fridge cabinet. The height of the shelf is very close to the height of the wheel well. But the weight is supported by the wood strips. This view is taken from the aisle looking at the wall closest to the sink side of the Fridge.
slapthecat
Excellent! Thanks for the picture.
