LED replacement for factory ceiling fluorescent
Posted: Sat May 27, 2017 4:43 pm
The driver circuit of our fluorescent ceiling fixture finally died. Rather than repair it, I decided to update the factory fluorescent light fixture for an equivalent LED model.
I installed the Thin-Lite model LED626P. The LED626P is virtually the same size and configuration of the Airstream factory fluorescent light.
The replacement is very easy…
1. Remove the lens of the light by squeezing the sides of the lens and pop it loose from the housing.
2. Unscrew four Phillips head screws that hold the old fixture to the ceiling panel.
3. Carefully, shift the wires that come through the hole in the ceiling until you can see the twist on wire caps. Grip the wire cap with a pair of needle nose pliers and carefully pull the wire cap and attached wires through the hole. Do this for both the positive and ground wires.
4. Remove the wire caps from the wires of the old light fixture.
5. Install the new light fixture by doing the reverse of the above steps.
Comparison of the old and new lights :
Light Type.........Control................Brightness............Power draw
Old fluorescent....On/Off................2200 lumens.........2.25 Amps
New LED............On/Off/Dimable.....2700 – 0 lumens.....1.2 Amps (full brightness)
The new light gets a thumbs up from us. More light, less power draw and dimmable. It’s a winner.
