Door Panel Restoration
Posted: Sat Jan 06, 2018 1:05 am
by usachris
I’d thought I’d share a relatively simple restoration project I’m just finishing up.
My door panels were stained, faded, and overall, very tired looking.
I removed the panels and thoroughly cleaned with TSP - Trisodium Phosphate. Once dry, I applied a paint adhesion primer, then used a Ford color matching spray paint and laid on 5 coats.
The image below shows the refurbished speaker grille on the bottom. The improvement was dramatic!
Believe it or not, the bottom speaker grille looked exactly like the one on the top before I refurbished it.
I finished both side doors and posted the pics in my gallery. I’m going to do the rear doors next week.
Re: Door Panel Restoration
Posted: Sat Jan 06, 2018 9:31 am
by Choptop
Nice work !!
Posted: Sat Jan 06, 2018 12:35 pm
by Kentuckian
I did the same when I upgraded the speakers in our doors. Amazing how doing something simple like refinishing the door panels takes years of age off the looks of the camper.
Nice work!
Posted: Thu Jul 05, 2018 8:28 pm
by GJCamper
I went ahead and removed, prepped, and painted the door panels. Wow! What a difference! I got the paint at O'Reilly's for about $8.00.
I need to remember to take before and after pictures. :D
Posted: Sat Sep 14, 2019 3:12 pm
by skidrow
That looks great. Did you do the front door panels too? I can't figure out how to remove them. Thanks.
Posted: Mon Sep 16, 2019 5:49 pm
by usachris
Thankfully the interior of my front doors were in great shape. So I had no need to remove and refurbish them.
Posted: Tue Sep 17, 2019 12:48 pm
by skidrow
I spent some time and figured that the carpet panel on the lower half needed to be pulled out and that revealed the screws for the upper half. My panels needed a refurb.
Posted: Thu Apr 15, 2021 3:29 pm
by con5
This is kind of an old post but when removing the side door panel in my 1998 there was some foam seal on the top side of the panel that filled the gap at the top of the panel where it is screwed in. The foam seems to provide some protection from rain but was completely ruined when I removed the panel.
Does anyone know what that foam is? It was high density, maybe 1/4-1/2" thick, and sticky on both sides.
Here is the little offset:
I used a little strip of plywood to fill the gap, but it is too thick, obviously not water-resistant, and probably not good to have that rubbing against the paint.
Posted: Fri Apr 16, 2021 7:13 am
Would stuff like this work to replace it? You probably don't need nearly that much, that was just the first example I found. It's readily available in hardware stores, Lowe's, Home Depot, etc.
Posted: Sun Apr 18, 2021 8:17 am
by con5
I’ll try something like that, thanks.
