Electrical and Vacuum manual
I bought an electrical and vacuum Ford diagnostic manual for the 1991 Econoline off eBay and received it today. It covers the electrical and vacuum systems of the van itself (engine, transmission, gauge cluster, cruise control, headlights, etc. - i.e., everything the van had before Airstream started on it).
If you are having an engine or body electrical or vacuum problem, post a new thread and I'll try to use that to diagnose it. It's probably good for vans from 1989 through 1991 (since they redesigned the body in 1992).
I'm already looking into why the gas gauge in mine doesn't work - and it's almost certainly a problem with the sender. (I'm also considering adding two aftermarket fuel gauges so I can see what's in each tank all the time after the senders are fixed...)
