Where do Mice typically nest on a B190?
Millennial Falcon
Post by Millennial Falcon » Mon May 06, 2019 4:24 pm
So where have you found a rodent nest on your B190?
I ask because... since the summer came and I've been in the heat I've been using fans a lot more. When my roof vent Maxxair is left on with the windows closed (or with not a BIG enough window open), it is pulling air from SOMEWHERE that smells of animal waste.
The scent appeared to come from mid/aft of the vehicle... so I pulled the microwave and I found a lot of droppings behind it in my 1994. I cleaned it out, Lysoled, and applied a liberal dose of Urine-B-Gone spray. That helped immensely, and the microwave compartment smells floral fresh now. However... if I operate boondock-style without AC for awhile... there is a not exactly faint smell of urine/mouse-poop that I assume is from air being sucked in over some old nest somewhere in the vehicle. I've opened all the cabinets and doors... and sniffed heavily... but I cannot seem to find it. I've tried opening all the doors on the outside of the vehicle, and see/smell nothing.
So, those doing rehabs... where have you found to be likely rodent nest areas? I am at a loss as to where this air is getting sucked in from, and where the smell is coming from.
Re: Where do Mice typically nest on a B190?
Post by skater » Tue May 07, 2019 1:01 pm
The exterior door latches on mine are not airtight (I think), so air can be pulled in that way. Have you looked in the door panels?
