Gutting the interior.
Make it comfortable inside
Wolfgangsballs
Post by Wolfgangsballs »
I started nitpicking at a few things in the scooby van. It has progressed to a removal of several items.
The Onan is refreshed. The lower bed is out as well as the tub.
The carpet and linoleum have also been removed. The toilet is next.
We will sand the floor, treat the wood to reduce moisture issues then use laminate flooring.
Electric upgrades; replace all current wiring, add USB ports aplenty.
Wolfgangsballs
Re: Gutting the interior.
Toilet and shower removed this pm. Tomorrow I will remove the water damaged panel and make a replacement. I plan to use marine grade plywood and stainless fasteners. Epoxy some vinyl laminate over the plywood.
calimike
Post by calimike »
keep us updated! very cool project ya got going on.
I'm interested in the roof connection if you are taking the ceiling cabinets off, I would like to see how the factory tv antenna railing is mounted.
Wolfgangsballs
Had a chance to do some more gutting this evening. I found some rot not only on the shower wall but in the refrigerator cabinet. The rotted pieces have been removed. I shall replace the removed pieces with marine grade plywood.
One thing I notecard was the refrigerator vent. It was not fastened. Is this normal?
Wolfgangsballs
Rot behind the shower wall
JoeD
Post by JoeD »
nice work. excited to see where it leads
Wolfgangsballs
Had time to do some more deconstruction. Starting the insulation.
