Lost power to monitoring panel
Posted: Thu Jul 02, 2020 9:52 am
by Jersey747
Hi Guys
Need your collective knowledge .... have lost power source to system monitoring panel AND furnace on switch ....... no fuses popped on house panel ..ANY ideas or fixes for this ???? It’s a 94 B190
Thx Paul
Re: Lost power to monitoring panel
Posted: Thu Jul 02, 2020 2:29 pm
Jersey747 wrote: Thu Jul 02, 2020 9:52 am
Hi Guys
Thx Paul
In mine, the switch for the panel is flaky and doesn't always trigger. Does the water pump switch work?
The furnace is usually a separate circuit. Note it doesn't start right away when it's triggered - like, turn it on, adjust the thermostat, then give it 20-30 seconds to see if anything happens. Another possibility is the thermostat went bad; pop the front off and connect the two wires to see if it starts then. If that fails, I'd check for voltage - one of the two wires should have 12 volts.
Posted: Wed Jul 15, 2020 7:09 pm
by Jersey747
Thanks Skater , sorry for delay in response ..... I figured it out ....I actually put a screw threw the wire harness while installing new cabinetry !!!!! All good now ...Some pics to post soon with new interior ...was a total gut job down to bare metal and fiberglass....way more work than I ever wanted to do ...total reconfiguration ..similar to Sportsmobile inside
Thanks P
Posted: Thu Jul 16, 2020 7:47 am
Jersey747 wrote: Wed Jul 15, 2020 7:09 pm
Oh, yeah, that'll do it every time.
Thanks P
Looking forward to seeing them!
