Tires and sizes
Jersey747
Tires and sizes
Post by Jersey747 »
Hi guys ...what are the largest tire size and rim combination you can install without rubbing on frame or requiring modification to bodywork etc ?. It’s a 94 B190 but has the running boards removed .....Will 33 in diameter tires work???
Thanks Paul
Jersey747
Re: Tires and sizes
Post by Jersey747 »
To answer my own question ......I found out today at Tire shop .... BF Goodrich AT tire 265/75/16 fit.....approx 32.5 in diameter with a bit of trimming to front fender...Tried the 285 but that would require a good chunk of rear wheel well to be chopped ..
So any bigger would require body or chassis lift kit etc.....hope that helps someone in the future
