Fridge gasket replacement?
Posted: Tue Feb 03, 2009 6:29 pm
Has anyone done this?
I decided to get one for mine, because I knew the bottom part of the gasket was leaking cold air. I figured this would help on those hot days when the fridge was struggling.
I ordered a new gasket from Dometic a couple weeks ago and it arrived within a couple days. Tonight I took the fridge door off and cleaned off the old gasket in preparation for the new one.
The gasket was about $150 shipped. In the kit, you get the gasket, double sided tape, silicone sealer, and - most importantly - excellent directions for removing the old gasket and installing the new one.
The old gasket was MUCH worse than I realized. It had hardened at the bottom, plus the metal strip inside had rusted. It took me a while to cut out the old gasket (new knife blade a must here!), but after I did that the mess cleaned up pretty easily with Simple Green.
I do have one tip already if you do this: Don't leave the gasket in the box leaning against a wall. The weight of the gasket was on one of the staples in the box, so the one edge of my new gasket is bowed inward. Not a big deal, I'm sure it'll go on just fine, but it means that the gasket isn't going to go where it should naturally (if that makes sense).
I also intend to sand the frame of the fridge where the gasket mates - there are a couple rust spots (I'm guessing water in the bottom of the fridge came out and rusted the frame and the gasket). I'll sand those smooth, then put a coat of paint on the frame. I don't intend to repaint the entire frame if I can avoid it...
