Looking for Transmission Dipstick for B190
Posted: Mon Jan 04, 2010 4:30 pm
by OnTheRoad
My airstream is built on the 1990 E-350 with the overdrive transmission (E4OD). Apparently at some point the transmission fluid dipstick on my van was replaced with one from the wrong vehicle.
Somehow it has a dipstick from a 1987 Van, which is too short -- this led recently to a shop adding way to much transmission fluid, which has been coming out of the overflow valve, and burning up on the exhaust -- a major hassle.
Does anyone know of a 1990 or 1991 van that is being parted out and might have the right dipstick? I've tried Ford, and a bunch of junkyards so far without any luck.
The part number is E9UP-7A020-BB or E9UZ-7A020-B
Thanks
Posted: Mon Jan 04, 2010 7:03 pm
by Alaskan
Maybe watch ebay...
put a "Wanted" ad in your local craigslist in the auto parts section
I just checked the measurement on my 1991 and it
measures 52" not counting the handle so I suspect that is what you are looking for.
Also checked my 2 other B190 (97 & 99) and guess what...they are 58".. !
Might give these guys a call..
http://www.autotransparts.com/cart.php? ... t_list&c=5
Posted: Mon Jan 04, 2010 7:21 pm
by OnTheRoad
Thanks. I'll check with them. The one I have is 45"
... It's good to know the 97/99 is longer. Maybe I can get one of those and cut it down.
Posted: Mon Jan 04, 2010 7:35 pm
by Alaskan
Put a "Wanted" ad in your local craigslist in the auto parts section
The problem with cutting one down is the neat little end they have...let me look at that a little closer....
Stay tuned, and a picture...
btw, the later ones are not flat metal, its round wire with a white plastic end....which makes it much easier to read... !
Posted: Mon Jan 04, 2010 7:58 pm
by Alaskan
Shortening one would be easy...not on the bottom
The diameter of the material is about 1/16"...
I'd clip it up at near the top (8 inches down) lay them side-by-side, and put a little silver soldier on it in two places
And...I did check and the inside diameter of the dipstick tube is the same.
As the E350 is still being produced you might just be able to order a new dipstick from Ford if you decide to shorten one...or it might be easier to find in used parts
The newer round-wire dipstick goes down the tube much easier than the flat metal one... !
Bottom...
Top...
Posted: Mon Jan 04, 2010 10:52 pm
by OnTheRoad
Do your newer dipsticks have a ford part number on them I could use for ordering? Otherwise I might be able to order one with the last part of your VIN - I think they need the final 6 characters.
Posted: Mon Jan 04, 2010 11:58 pm
by Alaskan
Nope...no part number. Its a pretty small wire so no place to put a pt #
The last four are 0321 and its a 97 E350 if that might help.
The flat one in the 1991 has this number: E9UP-7A020-BB
Posted: Wed Jan 13, 2010 3:26 pm
by Alaskan
Eli mailed me the transmission dipstick from his rig for lengthening...easily done with a doner dipstick
Laid side-by-side with the one from my 1991 there is a huge difference, which would result in his transmission being way over filled
