Sink Basket(Strainer-Stopper)
Posted: Thu Aug 04, 2011 8:38 pm
by Planck
Our "new" 1993 B190 has a double sink. The "baskets" are missing. Stopped at my local camper supply and they had 4 different styles, none of which would stop the water from draining.
Anyone know what type "basket" this sink takes, or can post a picture of there "basket" that I can show the dealer?
Thanks
Posted: Thu Aug 04, 2011 9:35 pm
Mine is missing, too. But the new trailer has them. Let me try one from the trailer in the B190 and see if it works...stay tuned.
Posted: Fri Aug 05, 2011 3:18 pm
by sparky
I found the same problem. Found a rubber drain plugof the cofrect size.
Posted: Fri Aug 05, 2011 6:10 pm
Okay, so the one from the trailer is the correct size, but a different design. The trailer one is 1-3/8" across the bottom part and 1-5/8" across the top of the basket.
The trailer one has a screw thing that you turn to stop the flow of water. The B190 does not have those threads - it looks like it's just a hole the strainer drops into (or it has the threads but they're much smaller).
Posted: Fri Aug 05, 2011 6:40 pm
by Planck
Skater
Thanks for checking it out. I think I will post a picture of the drain on the B190 and maybe from that you can tell if it is the same as your 91 or your trailer.
