ABS Light On?
Denco
ABS Light On?
Post by Denco »
My ABS light came on then went out after on/off of the ignition. Now its back and steady.
Speedo is smooth, van had the recall on the brake reservoir switch already done before I bought it.
All looks good there on the work that was done.
No leaks or obvious issues and the brakes work perfect.. ( I did a COMPLETE brake job <10k ago)
Any suggestions?
I did not find much here on the subject? Maybe I have missed something?
Thanks, Denco
ABS Light On?
Probably a wheel sensor went bad. You need to take it to a shop with an ABS scanner (the usual code scanners won't do the job).
Denco
Re: ABS Light On?
Post by Denco »
skater wrote:Probably a wheel sensor went bad. You need to take it to a shop with an ABS scanner (the usual code scanners won't do the job).
Thanks, yea these ABS issues are never often simple. Good advise thank you.
