Replacement for waste tank roof vent
Before condition :
Here is what the vent looked like when we purchased the B190. Factory roof cap missing, plastic cup for a cover, putty dried out & cracked, and factory vent plastic dry rotted and cracking.
- Old.jpg (214.79 KiB) Viewed 25496 times
We decided to replace the factory vent with the 360 Siphon product from 360productsinc.com.
Process :
1. Remove old vent,
2. Scrape off all old sealant,
3. Clean the vent pipe and roof (I used acetone) to remove remaining sealant and any oil and wax that might cause new sealant not to stick.
4. Drilled pilot holes for the new vent’s screws,
5. Sealed the old screw holes and around the vent pipe where it comes through the roof with an ample amount of urethane sealant. I also replaced the sealant around the antenna cable since it was nearby.
6. Applied urethane sealant to the mounting flange and in the screw holes of the 360 Siphon and screwed it in place to the roof.
7. Applied urethane sealant around edge of the 360 Siphon mounting flange where it meets the roof.
8. Done!
Process :
1. Remove old vent,
8. Done!
After condition :
360 Siphon in place
360 Siphon in place
- New.jpg (196.78 KiB) Viewed 25495 times
Pros :
1. According to the company the construction of the vent creates a mild suction at the roof vent when a breeze flows across it (vehicle stationary or moving). This mild suction draws air from the waste tank reducing potential of unpleasant odors in the cabin. A smoke chamber demonstration video is available at the company’s web site. I have no idea if it works. But, the concept is good and we are giving it a try.
2. Unit appears to be well made. Fit and finish is good.
3. Comes with sealant putty. I didn’t use it because I already had the Urethane sealant in my caulking gun.
4. Good online reviews.
5. Made in Canada (…not China which is a plus for me <smile>)
Cons :
Price is $29 compared to $2 for the factory replacement vent.
I will try to remember to add a note in a couple of months to let you know how it works.
Cons :
Re: Replacement for waste tank roof vent
It certainly looks nice!
Nice work !!
I had mine replaced right after we bought it. i was in a time crunch and had a dealer do it.
Just get on the Bus!!
Mike & Barbara
Mike & Barbara
What model/where'd you buy this cover? my vents been off for some time now i need to get on that. Also, do you know where you could find a factory replacement?
The vent that I installed is a 360 Siphon product from 360productsinc.com. I wanted to try something different.
One of these might be a replacement for your factory vent... http://www.rvlifestyles.net/c-15610-ven ... teid=10539
I didn't realize mine was missing. I have the cap over the pipe, but no housing! I did find pieces of it under the sealant, still screwed to the top. I can't find a picture of the original, but I'm *assuming* it's something like this here:
http://www.campingworld.com/shopping/it ... hite/35181
The question i'm having for anyone that can help - is the exhaust pipe that goes through the roof (inside the back closet on my '90) free standing? Or is it sealed to the roof on the outside? From what I can tell based on the plastic remnants and different types of sealant that were used, it looks like the housing was sealed to the roof, keeping water out, and the cap goes into the pipe, diverting rain to the outside of the housing - leaving the pipe floating through the roof. Is that correct?
The base would be sealed to the roof of the van, so it doesn't leak. I think you have the idea. If you have to replace the base, be sure to clean off all of the old gunk and reseal it well.slapthecat wrote:I didn't realize mine was missing. I have the cap over the pipe, but no housing! I did find pieces of it under the sealant, still screwed to the top. I can't find a picture of the original, but I'm *assuming* it's something like this here:
Slapthecat-
The way you described the mounting is exactly how mine was configured. "it looks like the housing was sealed to the roof, keeping water out, and the cap goes into the pipe, diverting rain to the outside of the housing - leaving the pipe floating through the roof. Is that correct?"
By the way, we have lived with the "360 Syphon" for a year and a half now with no concerns.
My 92 had an old ventline and the top came off. The current edition has a set screw that holds the cap on model V2049. If you scrape off the caulking you should see the mounting screws for the base. The mounting holes from the new model match the old one.
My local guy had a Camco Vent Kit - just about $7 - looks exactly like the vent pic in the previous post. There were two sets of holes in the van top - and this didn't line up with either! (Well, two or three holes lined up, but not enough to use) Rotated it a bit, filled in the old holes with some marine epoxy and drilled pilot holes for the next screws. Voila! She's is done!!!
