Floor Mats
- Mark
- B190 Year: 1997
Floor Mats
Would the floor mats (driver and passenger) for any Ford F350 work in my 97 B190? We have only carpet there now and I know it's going to get dirty and ugly quickly.
Re: Floor Mats
make sure you get E350 mats not F350 which is a pickup truck. I think any Econline mats should fit.
- B190 Year: 1998
- WBCCI: 16771
Re: Floor Mats
I'd like to know what you ordered. I've been searching for carpeted floor mats for the driver and passenger for our 1998 and I have not found any to my liking yet.Mark wrote:Thanks, I almost made that mistake.
I did order a set of clear Coverking mats from Amazon that I hope to use over the carpeted floor mats when I find a set.
http://www.amazon.com/Coverking-Custom- ... +1998+E350
We sold our 1998 B190, V-10
- Mark
- B190 Year: 1997
Re: Floor Mats
The ones I got didn't give me as much coverage as I wanted.
I ordered them here.
http://www.autoaccessoriesgarage.com/Fl ... -Econoline
- B190 Year: 1998
- WBCCI: 16771
Re: Floor Mats
If you have time to post a picture that would be helpful. I looked at the web site but there are several varieties of floor mats listed so I'm not sure which item you ordered.Mark wrote:The ones I got didn't give me as much coverage as I wanted.
I'll post a picture of the clear mats when I receive them later this week. I noticed Coverking makes carpeted floor mats too so if the clear ones look good I'll consider a set of carpeted mats from Coverking.
- Mark
- B190 Year: 1997
Re: Floor Mats
I don't have the invoice anymore so I can't tell you exactly the ones I ordered.
The material is nice but I wanted more coverage.
- Floor-mat.jpg (138.37 KiB) Viewed 15506 times
- B190 Year: 1998
- WBCCI: 16771
Re: Floor Mats
Yes, I see what you mean but carpeted floor mats typically are not "molded" so they only cover the relatively flat portion of the floor. In the case of an E350 the mats do not go up and over the bump created by the wheel well. I suspect the clear mats I ordered will be very similar.
A friend and former B190 owner suggested using the clear stick-on film used to protect carpet in houses during construction and realtor open houses. Apparently, big box home centers sell rolls of clear stick-on film and you cut a piece to protect the area. It doesn't last forever so you just cut another piece when needed. I may try that if the rolls are reasonably priced.
Re: Floor Mats
Interesting...our B190 had a rubber-ish floor covering (over the carpet) over the entire front area. We had small pieces of carpet to use as floor mats, and I always threw one on the ground for the poor guy who filled the propane tank.
I'd consider some of those heavy rubber floor mats (WeatherTech). We were always tracking in dirt, leaves, rain, snow, gravel, etc., and those would make it a lot easier to clean up. I kind of want to get some for our truck for the same reason, but it's hard to justify the cost when we already have floor mats.
Re: Floor Mats
In our 91 I installed some trim to fit rubber mats. When we bought the 93(newer body style) they did not fit as well. So, if ordering, make sure its for 92 or newer if you have the range of B190.
Phil
Phil
- B190 Year: 1995
Re: Floor Mats
Ikea sells a navy and black striped floor mat for 99¢. I bought 3 and cut them to fit the drivers and passenger side and the third fits perfectly in between the seats. Not fancy but for $3 you can't beat it.
Re: Floor Mats
Anyone have a lead on custom mats for the gen 1?
Re: Floor Mats
I think you may be out of luck, can't find them for the 2nd gen either, they are readily available for 97 and newer which doesn't help either of us!!!
