Upper windows on '89
BouldAndBeautiful
New User
B190 Year: 1987
Post by BouldAndBeautiful »
Has anyone had to replace one of the front upper windows on an '89 B190? I have an '87 Okanagan (almost the same van) which has very similar windows but one is now broken.
slapthecat
Re: Upper windows on '89
Post by slapthecat »
Check out this thread for info on the window manufacturer
http://www.b190.com/viewtopic.php?f=13& ... rame#p6064
BouldAndBeautiful
New User
B190 Year: 1987
I managed to find the Hehr part number on the window frame, but it's so old that ParKin couldn't provide a new pane for it. So, I cut a substitute from 1/8" thick, black HDPE on a CNC router, and I got new rubber for the gasket from ParKin. The CNC step took a couple tries to get the dimensions just right, and I've posted a drawing of the dimensions I ended up with. I'll add more photos once there's a little less snow on the vehicle.
Drawing:
Gallery:
http://www.b190.com/gallery2.php?g2_itemId=3466
Oldbagpipe
B190 Year: 1989
Post by Oldbagpipe »
This is good as it is my next step in my restoration. Anything else anyone might want to add before I start?
BouldAndBeautiful
New User
B190 Year: 1987
Be patient with yourself on the window vinyl. It only goes in by brute force, and not very quickly. On my vehicle, the stuff was available from here: http://www.parkin-acc.com/page53.html It was cross-section #G. If you're replacing a pane, make sure to thoroughly clean out the old window frame before putting in the new butyl sealant. I got good results with acetone.
Oldbagpipe
B190 Year: 1989
Brute force, I have. Patience, on the other hand, ....
Thank you.
