Bulb
- Choptop
Bulb
Went around swapping out interior bulbs w/ LED's, popped off the cover to the center, overhead fixture, the one that comes on when you twist the head light switch, mine doesn't because their is no bulb in their. Any one, off the top of their head, know what kind it is ajnd has anyone swapped that out for an LED ? Thanks
- usachris
Re: Bulb
I replaced all the indoor bulbs with these 650 lumens bulbs: http://tinyurl.com/y7f33z7q
And I wanted a brighter bulb for the dome light so I went with these 900 lumens bulbs: http://tinyurl.com/y9fpsxr7
Both bulbs fit in the sockets perfectly! They are LED bulbs and are much cooler and takes less energy to operate. Totally the way to go!
Oh, and for the porch light, I used this 1440 lumens bulbs: http://tinyurl.com/yag899rw
- Choptop
Re: Bulb
I replaced all the interior lights and the porch light, less the cab center map light and the florescent, w/the same 650 lumen bulbs. I like them, I will end up replacing the florescent w/some type of led fixture, as far as the map light, in the cab, they make an led for it also and I need to pick on up.
