Yes. Auto parts store, look in the Dorman/Help section. I got a pack for at most $10 of assorted pieces. They are different colors than mine was, but otherwise match exactly. (Actually I had to ream the hole out a tiny bit to get the rod in, I just used a drill bit to do it by hand.)Choptop wrote:
On my hood, the little white plastic thing that holds the left side of the" hood holder upper bar" is broken and the bar slips out sometimes and the hood comes crashing down, not on me yet, is that piece still available ?
Mine had a cotter pin in the end of the prop holding it in place, so the hardest part was getting that out before I could remove the prop to replace the plastic piece. A mirror helped me understand what I was dealing with. Sounds like yours doesn’t have a cotter pin.
Edit: Pretty sure this is the set - it’s the two pieces on the right in the picture.
