Basic (?) 12v wiring question
MarkP
Post by MarkP »
Ok, let's pretend that I'm a complete novice when it comes to wiring because, well, I'm a complete novice when it comes to wiring. If I wanted to add a 12 volt outlet like this:
To my van in order to power a 12v DC fridge like this:
Where does the negative wire go at the converter? If I'm correct I'll wire the positive to an empty circuit and add a fuse, but it's there sooner in the converter to hook the negative to? I know there's a negative block on the AC side but I don't see anything on the DC side. If it matters at all I've already replaced my stock converter with the 3 stage progressive Dynamics with the upgraded DC board. Thanks in advance for any assistance.
Sent from my Pixel 2 using Tapatalk
Millennial Falcon
Re: Basic (?) 12v wiring question
Post by Millennial Falcon »
Photos of your actual wiring/layout would help...
And someone may correct me, but your 12-volt system is probably wired so that the negative side of the circuit is the vehicle frame/chassis itself. So, you'd attach the negative side of the connection to any good solid metal connection in that case.
Same way most people connect the negative jumper-cable to a good frame/ground bite, instead of biting on the battery itself during a jump-start.
Millennial Falcon wrote: Tue Aug 27, 2019 9:47 am Photos of your actual wiring/layout would help...
Yep, just hook the red to positive and the black to any convenient ground (metal part).
Make sure the cooler doesn't pull more current than that adapter is good for, though. I don't know the numbers on either; just wanting you to be safe. (In particular, is the red wire heavy enough for the current draw?)
