B190 database
Re: B190 database
Please add me to the database.
1998 B190
Airstream VIN 1B9KGVA25WJ301293
Ford VIN 1FDSS34S0WHA02062
Is the database searchable or posted as public somewhere?
Thanks,
Tom
1998 B190
Thanks,
Tom
1998 B190 V10
Re: B190 database
Added! It's not online yet - it's the goal, but I haven't made it there yet. Too many projects! If you're wondering, though, this is the first I've seen yours - I don't have any prior records on it. Yours makes 205 in the database of the 1,393 we think were made (just under 15%).txtom wrote: Fri Mar 27, 2020 1:34 am Please add me to the database.
1998 B190
Thanks,
Tom
Re: B190 database
Hello! I have a beta version of the VIN lookup now available (see the navbar above, or click here). The map is not yet working, so right now it's just the table of results. The map is next, though.
You need to be logged in to use it, and you have to enter the Ford VIN, since we don't always have Airstream VINs.
Edit: Here's mine to get you started.
- Millennial Falcon
Re: B190 database
1994 Airstream B190
Purchased New From: Avalon RV Center, 1604 Medina Rd, Medina, OH 44256
First Owner: B. Toth
Second Owner: M. Bucur (Purchased on September 17th, 2018 with 24,500 miles, bought as part of an Estate Sale)
Current Owner: W. E. (Purchased on September 27th, 2018 with 24,574 miles, bought through B190.com forums)
Ford VIN: 1FDJS34G7RHA03012
Airstream Serial #: 1B9KGVA24RJ300706
RVIA #: 5134899
Owned by B190.com user name: Millennial Falcon, current mileage as of April 29th, 2020: 36,450 miles
Upgrades:
RVIA #: 5134899
Upgrades:
- 300 Watt Solar panels permanently mounted to roof rack
- 200Ah Lithium Battery Bank
- 2000 Watt Victron MultiPlus PureSinewave Inverter
- NovaKool R4500 Compressor Refrigerator/Freezer
- Maxxair 7000K MaxxFan Deluxe Fan with Remote
Last edited by Millennial Falcon on Thu Apr 30, 2020 1:17 pm, edited 1 time in total.
Re: B190 database
I've added yours! If you search on your Ford VIN in the B190 VIN History screen, it shows up.Millennial Falcon wrote: Wed Apr 29, 2020 1:27 pm 1994 Airstream B190
Current Owner: W. Edson (Purchased on September 27th, 2018 with 24,574 miles, bought through B190.com forums)
RVIA #: 5134899
Upgrades:
- Scot
Re: B190 database
I don't know how I missed this, but here is the data:
1994 B190 Airstream RV
Ford VIN 1FDJS3469RHA87690
Airstream Ser. No. 300791
161,000 Miles
Purchased at RV World in Nakomis, Florida on 6 January 1995
I am planning on putting this B190 on the market on 1 October. It is a one owner, garage kept, 190 in really good condition. I'm not sure how much to ask for it, but I believe that it is in much better condition than the 1995 that sold in April for $11,500.00.
161,000 Miles
Re: B190 database
Thanks. Looks like a beauty. I calculated the Airstream VIN as 1B9KGVA2XRJ300791; can you please double check that (under the hood)?Scot wrote: Thu Jun 18, 2020 5:29 pm I don't know how I missed this, but here is the data:
161,000 Miles
- Scot
Re: B190 database
That looks like the correct number. Two of the letters are not clearly stamped.
Re: B190 database
1FDSS34S3WHA00161 301297. Aluminess front and rear bumpers and UJoint conversion in process
Re: B190 database
Thanks. I'm getting 1B9KGVA22WJ301297 for your B190 VIN. Is that correct? (When I get only the sequence number, I have to calculate the Airstream VIN manually and can only do it by guessing the year of the B190 - well, in your case, it's in your profile.)PeteP wrote: Sat Jun 20, 2020 2:05 pm 1FDSS34S3WHA00161 301297. Aluminess front and rear bumpers and UJoint conversion in process
Also, where you are you located?
KeithLisaS
- New User
- B190 Year: 1996
Re: B190 database
In the process of purchasing a 1996 Airstream B190. Searched the database and it did not come up.
VIN: 1FDJS34G4THA31034
Re: B190 database
Added! You're right, there are no previous records for it. What is your approximate location?KeithLisaS wrote: Mon Jun 22, 2020 9:55 am In the process of purchasing a 1996 Airstream B190. Searched the database and it did not come up.
KeithLisaS
- New User
- B190 Year: 1996
Re: B190 database
Northern Utah, B190 purchased in Boise, Idaho
Re: B190 database
Re: B190 database
I've been staying out of the heat and working on the database, mostly on backend things that only I'll ever see. For example, I can now correct data without going into the database directly! I did update the output somewhat as well. I know it doesn't look much different, but it uses a better map setup, and as you can see, I have the popups finally working... well, they work on my local copy. These are just screen shots and won't work.
Next steps - switch to using the online database as the primary (as it stands now, I keep my local database current and just update the online one every now and then). Then I need to figure out if I want to go to the trouble of integrating it with the site, or if want to keep it essentially separate. Integrating it into the site likely means it'll have to be updated every time I update the site. Maybe I can fake it to LOOK like it's on the site but isn't actually integrated with the forum software. I've also amassed a pretty decent photo library of the B190s I've seen with VINs, so it'd be nice to somehow link those, but I haven't decided how I want to do that, yet.
