Vitrifrigo fridge install
mickle
B190 Year: 1998
Post by mickle »
Thought I would share some photo of my fridge install I did about 5 years ago in a '98. Its a Vitrifrigo compressor fridge, model C130 with external compressor unit. Has been working great. Much more space inside than the original fridge. It was a bit deeper than the existing space, so to fix that I build out a frame on the RV side, so it sticks out an inch or so into the RV. You can see the extra wood framing I added in the photo, stops just before the bathroom door trim.
con5
B190 Year: 1998
Re: Vitrifrigo fridge install
Post by con5 »
Hey nice work. I am considering the same.
con5
B190 Year: 1998
Post by con5 »
What is your battery setup to keep this fridge running? I think I saw on another post that you removed the generator.
