Can someone please let me know where the fuel shut off is for the generator.
I want to change the fuel filter but cannot locate the shutoff valve.
Fuel shut off for 93 generator
There isn't one....doesn't need one.
Back from that fuel filter about 18 inches is the electric fuel pump, it will prevent any fuel from flowing from the tank when you take the hoses off the filter...if you look closely down in the back of the left side of the gen, through those air-intake holes, in the rear you can see the fuel pump back in there.
It won't leak any fuel when you simply remove the 2 clamps and replace the filter.
