I've had the B-190 for almost 3 years and have had many adventures with it. Unfortunately, we had a pretty scary engine fire around WA Pass in Washington State. Some may know that this is a pretty good push up hill and can tax the engine pretty good. Well, the engine started racing, so I let off the gas. Tried the gas again, it caught, then raced again. Looked in the mirror and saw smoke, thought it was just overheating. Pulled over and lots of smoke now. Got out and looked underneath, fire and embers were dropping to the ground. Told my two passengers to get out and grab the fire extinguisher on the way out. I sprayed up into the engine from below. Fully discharged, didn't put it out. Two more people stopped and I sprayed up into the middle of the engine where the flames were coming, finally put out, but with a lot of smoke still coming out. Got the hood open with a bit of prying and started to shovel snow into the engine compartment. That seemed to help a bit. We then started to get gear out of the vehicle VERY quickly. This all happened within about 20 minutes. Luckily no one was hurt and it didn't go up in a ball of flames. About 2.5 hours later, it finally stopped smoking. Towed the next morning to an auto shop.
Anyone EVER seen this before with the van?
Unfortunately, the tow company, insurance company, and the mechanic says that it's totalled. Friends are saying that I'll have a LOT of problems from here on out even if I get if fixed. It'll also be hard to get the burnt oil and rubber smell out too. I'm having a VERY hard time accepting this since all electrical still works, there is no damage to the cab at all. Do you think it's salvageable or worth it? I'm guessing that most people here have sentimental attachment to this and could relate. But when do you say, no more? They told me they can't even give me an estimate on the damage unless they pull the engine out.
We've put a LOT of time, energy, and money into restoring and upgrading it. The tires and Bilstein shocks have less than 200 miles on them, JUST installed them
Also upgraded the power converter, ceiling fan, lights, and stabilizer shock in the front recently.
Thoughts?
B
